starts but stops immediately
Old Sep 18, 2005 | 02:49 PM
b20vtec crx's Avatar
Default starts but stops immediately
hey whats up guys i have an 89 crx si and i dropped a d16z6 motor in it and used the dizzy off the z6 motor well my motor will start but then stops immednitely
any help
Old Sep 18, 2005 | 02:54 PM
gray89si's Avatar
Default Re: starts but stops immediately (allshowcrx)
Is the Z6 you have out of an automatic or manual car?
Old Sep 18, 2005 | 02:56 PM
its out of a manual civic
Old Sep 18, 2005 | 02:57 PM
gray89si's Avatar
Is it converted from OBDO to OBD1?
Old Sep 18, 2005 | 02:59 PM
Josh.'s Avatar
did it start doing this immediately after you did the swap?
Old Sep 18, 2005 | 03:01 PM
Default Re: (Josh.)
it has an obo ecu and i used the obd1 dizzy jus connected my plugs to it, and yes it stared doing it immediately after the swap
Old Sep 18, 2005 | 03:10 PM
fireant's Avatar
Default Re: (allshowcrx)
If it actually starts up then just dies a second later, that's a problem I had once too on my stock motor.
I was also noticing a distinct smell of fuel when I smelled around my injectors. This was because my injector O-rings were deteriorated. I replaced them and the fuel filter as well, and the problem went away.
I suggest you look into a fuel related issue as well, and replacing the O-rings and fuel filter is only like $15 of parts and one afternoon of tinkering.
Old Sep 18, 2005 | 03:17 PM
Default Re: (fireant)
yeah cuz it jus starts up then dies right after i took the line off the fuel rail and had plaenty of fuel shootibg out the motor had beem sitting for A WHILE BEFORE I GOT IT
Old Sep 18, 2005 | 05:03 PM
Super Chicken's Avatar
Just a hunch, swap out your main relay and see if it still does it. I had a similar problem where my car would just die as I'm going down the road, I would stop and crank it over and it would start and run for 1-2 seconds and then die, if I tuened the key off and on a few times it would start and run fine til the next time. I just replaced my main relay and the problem went away.
BTW the main relay was fairly new too!
Cheeseburgers
May 31, 2017 05:50 PM
nycpatron
11
Mar 3, 2010 05:58 PM
meloylo
Nov 14, 2007 02:08 PM
underb00steg6
Oct 30, 2007 02:29 AM
