I'M DONE WITH HONDAS! Blowout Garage Sale in Massachusetts! ITR/GSR, Precision, Toda, HKS, and more!
Old Sep 18, 2005 | 01:08 PM
Sinitron's Avatar
Default I'M DONE WITH HONDAS! Blowout Garage Sale in Massachusetts! ITR/GSR, Precision, Toda, HKS, and more!
Ok, I'm done! After owning two Preludes, an ITR, CRX, turbo-EJ, and other Honda/Acura products, I'm calling it quits. I've finally sold off my race car, and I'm getting rid of all my extra parts. I'm growing up and moving onto owning a regular car, having a family, and getting on with my life.
Everything below is CHEAP if you come pick it up. I'm about 30 min south of Boston, in the south-shore area. Otherwise, I can take Paypal, and ship the stuff USPS Priority mail, or possibly UPS ground, but I'll only be available to ship things on Saturdays now that I work 6am to 7pm during the week.
I've sold three cars on H-T, a million parts, and I've got a stack of vouches. Don't worry, you'll get your parts well-packed, with a tracking number as always, but I can't ship every day like I used to.
Drop me a PM or an E-mail if you have any comments or questions, Thanks!
2001 Acura Integra GSR crank. Journals look to be in good condition. Came out of a tear-down and the bearings looked good. Had the GSR rods / SRP pistons mounted on it listed above. $100 picked up.
Unorthodox Racing billet silver tripple-groove B-series crank pulley. Used for a couple thousand miles. $100 shipped
Acura/Honda OBD-0 cut LS distro for old B16a/CRX type swaps. $100 shipped
Distributor-King TD-44U OBD-1 distributor for B-series. No ignitor chip or rotor, was using it just for a trigger. $100 shipped
Acura/Honda Ignition coil. Working condition. Best offer.
92-95 Civic Hazard Switch. works fine. $10
92-95 Civic white-led replacement clock. best offer
NRG 92-95 civic engine damper. Never used, new in box, silver. $50 picked up, $60 shipped.
Acura Integra Intermediate Shaft for b-series swaps into 88-91 civic. For use with 90-93 integra axles to complete your project. $50 picked up
Complete 92-95 Civic EX OBD-1 wiring harness (un-cut). I think I have two of these, I just found a second. $120 shipped
Suspension Techniques Swaybars for 88-91 Civic/CRX. Brand new, bars only, no hardware, never been installed. $100 picked up only.
Black Projector headlights for 90-91 Civic/CRX (brand new in box), clear projector lenses (not blue tinted, and no silly 'halo / angel eye' rings), includes 9005/9006 bulbs.$100 Shipped.
APC 94-97 Accord Euro Corners. New in box, $20 Shipped.
APC 90-91 Civic clear bumper lenses. $20 Shipped.
APC 90-93 Integra clear corner lenses. $20 Shipped.
APC 92-93 Accord clear bumper lenses. $20 Shipped.
MSD ignition caps, two left, one of each:
#8290 - 1988-91 1.5L/1.6L Civic, CRX, or 1988-91 1.6L/1.8L Integra $40 Shipped.
#8291 - 1993-97 2.2L Accord with Hitachi distributor $30 Shipped.
Vibrant Mass Air Flow Adapter for Mitsibushi vehicles. Accepts 4.5" I.D. air filter. $20 Shipped.
PIAA Superwhite bulbs. 9005 and 9007 headlights: $40 Shipped ea.
PIAA Superwhite bulbs. H3's, 1156, 1157, w2's, and corner wedge bulbs $15 Shipped ea.
HKS Super Sequential cast flange for 93-98 Toyota Supra TT (to be a bolt-on). $20 Shipped.
Honda OEM B-series Vtec windage tray. Used but damn good condition. $25 Shipped.
***** STUFF THAT IS SOLD *****
2001 Acura Integra Type-R head. Includes cam caps and rails, springs, retainers, rockers. SOLD LOCALLY
1995 Civic EX seats: Bare seats, no brackets, Dark Grey, pretty damn mint. SOLD LOCALLY
Acura Integra Type-R cams 98-spec. Came out of my ITR with about 20k miles on them. Toda racing cam gear is NOT included. SOLD LOCALLY
Inline-Pro stainless 5-bolt 2.5" downpipe welded to 2.5" test pipe. This was bolted up to a Greddy cat-back at one time, but when I went with all 3" parts, it sat in the closet. I think it had a slight leak around the flex section, but still works fine as a cheap bolt-on. SOLD LOCALLY
2001 GSR rods with SRP 9.5:1 GSR semi-dished pistons Part Number 149237 (9.2:1 with b16/ITR head) rings, and rod bolts. Rods have been machined to accept JE floating wrist pins. JE pins included, obviously. 81.50mm bore (20 thou over) These came out of a boosted motor before the entire setup got dismantled, sleeved and rebuilt. They're cleaned up, and ready to go if you want some cheap parts to play with. SOLD TO 95 integra.
2001 Integra Type-R Intake Manifold, no sensors, perfect shape otherwise. SOLD TO 95 integra
Golden Eagle vacume manifold. This was silver, and I had it powdercoated black so it wouldn't have the machined writing on it. New and never used. SOLD TO
IN VTEC
Toda Racing Cam gear set. I actually have 3 gears. If you want the third gear, PM me and we'll work out a discount, its still mounted to the ITR cam showin above.
SOLD. LOCAL PERSON PICKED THEM UP. NO GEARS LEFT!
Just added: P28 ECU chipped / prepped for Uberdata / Hondata / whatever. I think I sent this out to get done at some vendor on H-T to get done, got it back, and never used it (used aem ems instead). SOLD to Brandon W, along with spare single Toda Cam Gear.
Golden Eagle cam seal. Tripple o-rings, barely used. Sold to 94maroonturbocp
Taylor "Pro 409" 10.5mm ignition wires. For DOHC VTEC B-series! These are the best ignition wires I ever owned. They measure 6-7 ohms for the entire wire, where my old MSD's measured 100-200 out of the box. They kicked ***, and I used them for probably a thousand miles before I went coil-on-plug. SOLD to 94maroonturbocp
Acura Integra GSR polished valvecover w/ polished billet plug cover. Cover is cut on the right side to allow access to the cam gears. I had this polished long ago, and it sat on a shelf for years. Its a little cloudy, but will shine right up with some aluminum compound. SOLD to 94maroonturbocp
HKS Super-Sequential (SSQ) Blow of Valve. I had the shell powdercoated black, to match all my other black components. Includes aluminum weld-on flange, and is in perfect working order. SOLD to nemesis08
Acura/Honda OBD-1 GSR/ITR distributor. This thing has been gutted of its ignitor chip, wiring, and most of the rotor. I was using it with my AEM EMS just to trigger the ignition. SOLD to ludedeg
Vibrant Stainless straight-through muffler w/ removable silencer. 2.5" inlet, includes stainless hanging ring. Brand new in box.SOLD to marcosh
Modified by Sinitron at 10:53 AM 11/19/2006
Old Sep 19, 2005 | 05:44 AM
Sinitron's Avatar
Default Re: I'M DONE WITH HONDAS! Blowout Garage Sale in Massachusetts! ITR/GSR, Precision, Toda, HKS, and m
Bump to the top!
Old Sep 19, 2005 | 12:20 PM
Sinitron's Avatar
GSR rods / SRP pistons, ITR intake manifold, and GE vac manifold are sold.
Old Sep 19, 2005 | 12:34 PM
Chugger's Avatar
interested in cam gears let me know if they are still available
Old Sep 19, 2005 | 03:00 PM
Sinitron's Avatar
Default Re: (Chugger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chugger &raquo;</TD></TR><TR><TD CLASS="quote">interested in cam gears let me know if they are still available</TD></TR></TABLE>
I have two in the box, ready to go (see above).
I have a third available, if you want/need it. The fourth gear got sold on my car, so I'm left with an extra. I couldn't use it as a traditional pair, because I was running a custom magnetic trigger using a machined GE cam gear.
Thanks,
Old Sep 20, 2005 | 08:31 AM
IN VTEC's Avatar
Default Re: (Sinitron)
bump
Trying to get dibs on the crankshaft. I'm thinking that I'll probably take it even if you can't get the pictures by the Saturday.
Old Sep 20, 2005 | 09:08 AM
MAV3RiCK478's Avatar
Default Re: (IN VTEC)
how much for the td44u(with wiring) and the ignitor shipped to CA 95407? my cousin would definately be interested.
Old Sep 20, 2005 | 10:51 AM
Sinitron's Avatar
Default Re: (MAV3RiCK478)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAV3RiCK478 &raquo;</TD></TR><TR><TD CLASS="quote">how much for the td44u(with wiring) and the ignitor shipped to CA 95407? my cousin would definately be interested.</TD></TR></TABLE>
Hey there,
The TD44u is shown "as-is", It doesn't have an ignitor chip in it. I wasn't using most of the internals, since I switched to coil on plug, and was just using the distro as a trigger (which was also later replaced).
I may have an ignitor chip laying around, if I do, I'll throw it in the box for free and you guys can figure it out. If you have an existing distributor, you can probably mix and match parts to put a working unit together.
Let me know if that works for you.
Thanks,
Old Sep 20, 2005 | 11:07 AM
CivicNewbie's Avatar
Wonder if the Inline-Pro downpipe will work with B-series Drag3 manifold?
Old Sep 20, 2005 | 11:08 AM
oh duh, thats a coil under the distributor with the wiring, for some reason i thought it was an ignitor
but that distributor has everything but the rotor and ignitor right? i'll let my cousin know about this and get back to you.
Old Sep 20, 2005 | 12:01 PM
Sinitron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAV3RiCK478 &raquo;</TD></TR><TR><TD CLASS="quote">oh duh, thats a coil under the distributor with the wiring, for some reason i thought it was an ignitor
but that distributor has everything but the rotor and ignitor right? i'll let my cousin know about this and get back to you. </TD></TR></TABLE>
Yeah basically.... take a new distributor. Take off the cap, take off the rotor, take out the coil + ignitor chip (with metal backing plate), and that's what is left. I may have some random distributor pieces around, and I'm sure I do, but I haven't had a lot of time to search. That's why I listed the distributors "as-is" for parts. The obd-0 / b16a distributor works fine, and the other two work fine as pickups.
Old Sep 20, 2005 | 01:52 PM
b17integra's Avatar
pm sent
Old Sep 20, 2005 | 02:10 PM
iH8RICERZ's Avatar
Default Re: (b17integra)
awesome price on that itr head!!! free bump!
Old Sep 20, 2005 | 03:27 PM
Sinitron's Avatar
Default Re: (iH8RICERZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ &raquo;</TD></TR><TR><TD CLASS="quote">awesome price on that itr head!!! free bump!</TD></TR></TABLE>
Thank you!
Everyone Who Reads This Thread, these are a few notes from the PM's I'm getting, maybe they will answer some of your questions:
No I will not do "100 shipped" for the crank. You are on crack.
No I will not do "shipped" on the HEAD. You are ALSO on crack.
The downpipe would need a LONG box, and to be packed fairly well. If nobody comes to pickup these three items locally, I'll revise my prices with "shipped" price adjustments.
If you want any of the heavy stuff, it will require at least professional double-boxing, or crating with foam if you expect to get it in once piece. I'm near Boston, generally the further away you are, the less chance of it showing up intact. This will cost money, and I'll get a quote on shipping the item the right way. I'd rather do that, than have to hear someone BITCH about it later when it arrives in pieces / smashed / broken / lost / etc. and blames me for it, because they wanted the price to include shipping. It works out better this way for all of us.
Thanks for looking!
Old Sep 21, 2005 | 06:06 PM
Sinitron's Avatar
Toda cam gears (the pair new in the box) are sold. A local person drove down and paid cash for them.
I have one spare extra Toda cam gear remaining.
Old Sep 21, 2005 | 06:16 PM
JdmH22Acorn's Avatar
i will take the type r cams 280 picked up rite. im in CT 20 mins for springfield
Old Sep 22, 2005 | 02:06 AM
Sinitron's Avatar
Default Re: (JdmH22Acorn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmH22Acorn &raquo;</TD></TR><TR><TD CLASS="quote">i will take the type r cams 280 picked up rite. im in CT 20 mins for springfield</TD></TR></TABLE>
No problem. PM me for address and directions. I should be around Saturday and Sunday.
Thanks,
Old Sep 23, 2005 | 11:28 AM
Sinitron's Avatar
Tomorrow is shipping day!
PM me if you want to have something sent out...
Old Sep 23, 2005 | 01:50 PM
94maroonturbocp's Avatar
I want the valve cover, wires, and cam seal. sent pm
Old Sep 23, 2005 | 03:16 PM
Sinitron's Avatar
Default Re: (94maroonturbocp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94maroonturbocp &raquo;</TD></TR><TR><TD CLASS="quote">I want the valve cover, wires, and cam seal. sent pm </TD></TR></TABLE>
Those items are pending to you sir. I'll ship them out tomorrow AM if the paypal rolls through tonight.
Thanks,
Old Sep 24, 2005 | 10:13 AM
Sinitron's Avatar
Everyone who has purchased something, your items all shipped today!
Check your mail for tracking numbers.
94maroonturbocp: If you paypal me for those items, I'll try to get them out when I can...
Thanks,
Old Sep 25, 2005 | 01:53 PM
Sinitron's Avatar
Bump for new parts added.
Old Sep 25, 2005 | 06:09 PM
JUSTCRX's Avatar
emailed.
Old Sep 26, 2005 | 04:11 PM
Sinitron's Avatar
JustCRX: Bars are pending to you when you want to ride out and pick them up.
94maroonturbocp: I'm waiting for you to Paypal me for the valvecover/insert, wires, and cam seal, so I can mark them as sold and ship them out.
Del Sol radiator + NRG damper should be picked up on Saturday.
ITR head and ITR cams may be pending to chulowithakhulo. He wants to drive out and pick them up.
Old Sep 29, 2005 | 03:07 PM
Sinitron's Avatar
Shipping and packing day is tomorrow. If anyone needs anything, now is the time to grab it so I can ship it out Saturday, before another week goes by!
94maroonturbocp: Still waiting for paypal! Drop me a line!
