how do i check my main relay and neutral safety switch with my multimeter
power from battery: 12.4v
power to starter: 12.4v
power from signal wire when turned to start: 0.0v
starter: ok
how do i use my multi meter to check the neutral safety swith. theres a plug just above the pedal and on alot higher. what do i set it two and what should i be looking for. can you test your main relay, (i think its good)?
93civic si, sir-II lsd swap
starter: ok
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG93si »</TD></TR><TR><TD CLASS="quote">power from battery: 12.4v
starter: ok
</TD></TR></TABLE>'
You mean your clutch switch? It's the upper one. It should be closed with the pedal pushed down, check with the ohm reading.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG93si »</TD></TR><TR><TD CLASS="quote"> can you test your main relay, (i think its good)?
I usually check them for cracked solder jopints.
starter: ok
</TD></TR></TABLE>'
Darrell Woods
Sep 7, 2018 06:09 AM
eastcoastmenace
21
Mar 21, 2015 06:43 AM
ahem ahem
Aug 23, 2009 06:28 PM
VtecLsEater
Jul 7, 2009 08:14 AM
KtHaNxBai
Jan 27, 2007 08:02 PM
