JDM LS motor question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redDAinteg »</TD></TR><TR><TD CLASS="quote">will a jdm LS motor feel stronger than my 161xxx mile usdm b18a1 ?</TD></TR></TABLE>
yes it will feel a bit stronger, i swapped my b18a1 with about the same amount of miles for the jdm b18b and it was much better
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by low430 »</TD></TR><TR><TD CLASS="quote">Will I see gains with A JDM ECU
You probably won't feel any difference. However, you will now have a speed limiter at a pretty low speed. Aren't JDM Honda Integras limited at like 113-120 or something?
EDIT: ....not that you should be driving that fast anyway. ::cough::
</TD></TR></TABLE>You probably won't feel any difference. However, you will now have a speed limiter at a pretty low speed. Aren't JDM Honda Integras limited at like 113-120 or something?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo »</TD></TR><TR><TD CLASS="quote">
112mph
</TD></TR></TABLE>112mph
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redDAinteg »</TD></TR><TR><TD CLASS="quote">are you using the stock ECU DAmn ?</TD></TR></TABLE>
when i first swapped the jdm motor in i was on the stock obd0 ecu. Im now converted to obd1 and on hondata(much better than the stock ecu)
