Installed GSR front brakes, and alignment is way off on passenger side now. Need Help!!
Old Sep 18, 2005 | 10:04 AM
Slammd Sol's Avatar
Default Installed GSR front brakes, and alignment is way off on passenger side now. Need Help!!
I have a '95 del sol S which comes with the 9.2" brakes in the front. I got a set of Integra 10.2" brakes (Knuckles,hub, rotors,calipers etc) from a 2000 GSR. After the install my camber is horribly off on the passenger side. My car is lowered but i have a camber kit on it. With the camber kit adjusted all the way out, I am still -2degrees, but only on the passenger side. Driver side is good. I took it to get an alignment and see if they could fix it, but they couldnt, stating that the camber was adjusted all the way and that something had to be messed up. Could it be possible that the knuckle or something else from the GSR setup was bent. Anyone else have this problem? Could I just have forgot to do something?
edit- If the Knuckle turns out to be bent, can I use my stock knuckle from my del sol S (9.2" brakes) to replace the bent GSR one?...
Modified by Slammd Sol at 2:18 PM 9/18/2005
Old Sep 18, 2005 | 10:55 AM
dc2vu's Avatar
my buddy had this problem before...check everything you took apart to put the brakes in...his problem was that his suspension wasnt put back into the fork correctly...im a little blurry on the details but thats just the jist of it...good luck!
Old Sep 18, 2005 | 10:57 AM
Slammd Sol's Avatar
I didnt touch the fork. The only things I removed were the upper and lower ball joints, the tie rod ball joint and the axel nut. I then slided the whole assembly out.
Old Sep 18, 2005 | 11:05 AM
Bcuz's Avatar
Default Re: (Slammd Sol)
You pulled apart your knuckle ofcourse the alignment will be off, just do one or get one done, you'll be good.
Old Sep 18, 2005 | 12:32 PM
Slammd Sol's Avatar
Default Re: (Bcuz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bcuz &raquo;</TD></TR><TR><TD CLASS="quote">You pulled apart your knuckle ofcourse the alignment will be off, just do one or get one done, you'll be good.</TD></TR></TABLE>
I went to get it aligned and they couldnt align it because something is messed up. My camber kit is all the adjusted to the max and it still wouldnt remove the negative camber I had.
Old Sep 18, 2005 | 02:08 PM
Slammd Sol's Avatar
I am having a very similiar problem that this guy had:
https://honda-tech.com/zerothread?id=751200
Old Sep 18, 2005 | 02:15 PM
Archidictus's Avatar
Unceasing Measure
Take it all the way apart and put it back together again. Jesus Christ, what do you want from us, a magic ******* potion? You obviously did something wrong, probably something small, but something wrong nonetheless. Do it again.
Old Sep 18, 2005 | 02:55 PM
Slammd Sol's Avatar
Default Re: (Archidictus)
Just finished redoing it for the third time. Everything is sitting properly.
saveacivic
Sep 15, 2007 04:11 PM
Kool305
Feb 1, 2007 03:35 AM
eg2phosizzle
Mar 18, 2006 06:09 PM
blazin247nc
18
Jan 10, 2005 10:32 AM
Kool305
Feb 1, 2004 11:40 AM
