how can I get more power without upgrading internals on 99 gsr hatch?
Old Sep 18, 2005 | 08:58 AM
ndlyng's Avatar
Default how can I get more power without upgrading internals on 99 gsr hatch?
I have a 99 gsr hatch with is stock. I hit 14.4 at the track with street tires-khumos. I have :
skunk2 intake manifold
3" short ram w/ foam filter
2" exhaust with high flow cat
P28 chip/9k
DC 4-2-1 header
aem fuel rail
aem fuel filter
gsr fuel pump
h22 throttle body
gsr radiator
b&m fuel regulator
everything else is stock
Is there anything else I can upgrade externally with out internal upgrades on the engine?
Modified by ndlyng at 10:05 PM 9/19/2005
Old Sep 18, 2005 | 09:08 AM
8Si8's Avatar
Default Re: how can I get more power without upgrading internals on 99 gsr hatch? (ndlyng)
yeah get a fidanza flywheel and upgrade the clutch you will really love the way it revs then. also don't forget about nitruos
Old Sep 19, 2005 | 07:06 PM
ndlyng's Avatar
Default Re: how can I get more power without upgrading internals on 99 gsr hatch? (8Si8)
I'm talking about stuff like bigger injectors or throttle body? would those make a difference with my setup?
Old Sep 19, 2005 | 07:46 PM
Squirtin EGsr
Guest
Posts: n/a
i did a 13.8 with a bone stock GSR in my hatch you should be running a lil faster then what you are
Old Sep 19, 2005 | 09:58 PM
e9's Avatar
e9
Default Re: (Squirtin EGsr)
The biggest difference will come from proper tuning that chipped ecu is a joke - hondata ect.
my daly driver b16 with bolts on befoe and after s100 tuning - oh and the gs mileage is way better too
Old Sep 19, 2005 | 11:05 PM
Icey112's Avatar
if your trying not to spend alot of money and get alittle more power look at getting a better header something like the megan 4-1 you can find them for around $150-$200 new.a diy ground kit, lighter fly wheel/ clutch,alittle big exhaust like 2'' 1/2,intakemanifold like blox, sk2 you can find them on the board all the time for good prices. and no the injectors and throttle body will not help you; your car is stock still. and look into hondata and get it tuned .
Old Sep 20, 2005 | 07:19 AM
Jason.H.'s Avatar
Default Re: how can I get more power without upgrading internals on 99 gsr hatch? (Icey112)
true 2 1/2 exhaust, throw away that header and get an rmf, get hondata (chrome, uberdata) which ever and clutch and flywheel and ul be in 13's easily
Old Sep 20, 2005 | 09:41 AM
WhiteGSR95's Avatar
hondata and get rid of that POS header
Old Sep 20, 2005 | 09:53 AM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondagod &raquo;</TD></TR><TR><TD CLASS="quote">true 2 1/2 exhaust, throw away that header and get an rmf, get hondata (chrome, uberdata) which ever and clutch and flywheel and ul be in 13's easily</TD></TR></TABLE>
second.
add, get a j's style intake. like the password jdm one, and kteller exhaust w/ straight through oval muffler. check sponsors section for deals..
and also some better tires. whether you want to get drag radials, or street slicks.
Old Sep 20, 2005 | 10:03 PM
biassj's Avatar
Default Re: how can I get more power without upgrading internals on 99 gsr hatch? (dfoxengr)
Cold Air intake, Hondata, better header.
Old Sep 20, 2005 | 11:19 PM
Icey112's Avatar
**** the j's inatke i lost 12whp and 8 tq at the wheels **** that get something like the aem type r intake if any.
Old Sep 21, 2005 | 03:50 AM
dfoxengr's Avatar
did you get it tuned? what was your setup
Old Sep 21, 2005 | 05:32 AM
DOMKID's Avatar
sell your gsr tranny and use that money + $300 and get a b16 or itr tranny. You can also add a 4.7fd to your current gsr tranny.
Old Sep 21, 2005 | 08:48 AM
ndlyng's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">did you get it tuned? what was your setup</TD></TR></TABLE>
I have not gotton it tuned yet. Just ran with what I got. I will have to invest in a fuel management system then...
Old Sep 21, 2005 | 08:51 AM
dfoxengr's Avatar
i was talking to the guy above my last post.
Old Sep 21, 2005 | 10:12 AM
ISPhuevos's Avatar
bro get some slick i ran 14.2 on a bone stock ls just had b16 tranny blox man. slick 22/15/8 MT non lsd and enegry bushing inserts in the motor mount no internals. And my 13.8 on couple dx 2000 w/gsr same set up
Old Sep 21, 2005 | 10:28 AM
2k.civic.si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Icey112 &raquo;</TD></TR><TR><TD CLASS="quote">add, get a j's style intake. like the password jdm one, and kteller exhaust w/ straight through oval muffler. check sponsors section for deals..
**** the j's inatke i lost 12whp and 8 tq at the wheels **** that get something like the aem type r intake if any.</TD></TR></TABLE>
j's intake blows for drag racing...to many dyno sheets where aem cai just kills j's from about 5k on....i myself own a real j's intake and went back to my aem cai...
Old Sep 22, 2005 | 04:45 AM
Sahwn's Avatar
If i am reading your mods correctly then u don't have any upgraded cams. Are you reving to 9k? If so, I am sure that is Killing you. Your cams aren't worth a **** over 8200rpms and probably be better shifting a little lower than that. Not to mention you don't have an upgraded valve train. Get some cams, cam gears, valve train. RM22 with chip and valve train are around 1k and some cam gears are around $110(aem 5 bolts). Then if you have money up grade the exhaust system. Then tune it! I know u said no internal work but u will need some for more power and that is minimal internal work.
Old Sep 22, 2005 | 07:13 AM
dfoxengr's Avatar
Default Re: (rsg74)
as stated above. a good cam package like the Rocket m22x will do you good too...
Old Sep 22, 2005 | 07:37 AM
Sahwn's Avatar
Most over looked is SUSPENSION. Get some full coilovers($~650) and polyurethane motor mounts($50)....eliminate that wheel hop. Sway/tie bars too! Don't know if u have power steering or A/C but eliminating the belts would be FREE HP! Hell dropin the A/C would be some weight too. Depends on what u wanna do.
Old Nov 26, 2005 | 10:28 PM
HB VTEC's Avatar
get a traction bar and drag radials..stage 1 axles..ctr crank pulleyand tune with hondata...good luck
jdmbeegee
Jan 26, 2007 09:22 AM
impact_blu
30
Aug 20, 2005 08:46 AM
typesguy
Nov 24, 2004 09:07 AM
DocIowa
Feb 18, 2004 09:26 AM
