type-r swap for sale everything new
swap for sale
new b18c5 block from acura
new je piston 12.5:1
new type-r flywheel
new exedy stage 2 clutch kit
new axles
mid shaft
2000 b16a2 head
new valve seals
new valve guides
comes with intake,injectors,throttle body(gsr)
new toda timing belt
everything is obd1
chipped po6 ecu
usdm exhaust manifold
99 jdm type-r trans lsd
make an offer,pm or call 616-706-2962
new type-r flywheel
new axles
mid shaft
2000 b16a2 head
new valve seals
new valve guides
everything is obd1
chipped po6 ecu
92civicsib18c5
Sep 30, 2005 01:19 PM
