Bought car last week...worked fine, now 5th gear grind? HELP!!?!?
Old Sep 18, 2005 | 07:57 AM
Integra_RS's Avatar
Default Bought car last week...worked fine, now 5th gear grind? HELP!!?!?
Well, i recently purchased a 94 Civic Hatch, with a B20VTEC setup, JDM B16A tranny with a GSR 5th in it. All the work was done locally. Went for a test drive in it, worked perfect! I've been driving it the last week fairly easy, very easy on the car itself & the drivetrain...no burn outs or anything. Then last night, as I go to put the car in 5th gear, it starts to grind. I tried a couple tests. I have the clutch ALL the way down on the floor, try putting it into 5th at around 30 MPH very easily & hard & both times it grinds. It WILL go into 5th, just grinds going into it.
So I pull the car over & while stopped, I put the clutch in...shifted 1-2-3-4-5 & EVERY gear went in like butter. Took off, got up to 30, & put it into 5th & it also went in like butter. Then I came to a complete stop, took it up to 30, put it in 5th & a small grind again. It only makes the grinding noise while the car is in motion, but when stopped, it goes into 5th PERFECT!...I dont understand whats going on here... Anyone have any idea's? I took the car home after all of this & just drove in 4th but i REALLY need that 5th... The car has been known around this town for a while & has never had a problem until last night. Someone please give me an idea here!
-Ryan
Old Sep 18, 2005 | 08:01 AM
slowman's Avatar
I took way too long
Default Re: Bought car last week...worked fine, now 5th gear grind? HELP!!?!? (Integra_RS)
IDK try some Syncromesh tranny fluid maybe..??
Old Sep 18, 2005 | 08:59 AM
Mwsol's Avatar
Default Re: Bought car last week...worked fine, now 5th gear grind? HELP!!?!? (slowmanEJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowmanEJ &raquo;</TD></TR><TR><TD CLASS="quote">IDK try some Syncromesh tranny fluid maybe..??</TD></TR></TABLE>
Couldn't be bad to not try this.
Old Sep 18, 2005 | 09:18 AM
.Ry's Avatar
.Ry
Default Re: Bought car last week...worked fine, now 5th gear grind? HELP!!?!? (Mwsol)
The reason it doesnt grind at a stop light is because their isnt a load on the engine. There IS a load when your moving. Try that Sycromesh first its the cheapest way to start. It takes a few hundred miles I belive before it really gets to work. I got mine at Autozone for like $5-$6 bucks a bottle and you should need 2. When the search engine comes back online try a search for it.
Old Sep 18, 2005 | 09:30 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Bought car last week...worked fine, now 5th gear grind? HELP!!?!? (turner7205)
Either way it sounds like your 5th gear synchro's are bad.
Old Sep 18, 2005 | 09:58 AM
Integra_RS's Avatar
How much are they to replace?
Old Sep 18, 2005 | 10:50 AM
.Ry's Avatar
.Ry
Default Re: (Integra_RS)
Well the sycros arent hard to replace its getting to them. Serioulsy try the Sycromesh and see.
Old Sep 18, 2005 | 07:04 PM
Integra_RS's Avatar
**UPDATE**
Fluid did NOT help. We do know this though, if i shift into 5th in a low RPM such as 800-1000 RPM, it will not grind...but if i shift anything over 1000 RPM...it will grind. This sucks
Old Sep 18, 2005 | 07:14 PM
.Ry's Avatar
.Ry
How many miles did you drive? If you drove around town a bit and didnt help at all then reguardless your going to have to pull the tranny.
Old Sep 18, 2005 | 08:50 PM
Integra_RS's Avatar
I realize that now
Old Sep 18, 2005 | 08:53 PM
.Ry's Avatar
.Ry
sorry lol
Old Sep 18, 2005 | 09:08 PM
hondakevin21's Avatar
Just out of curriosity why are you shifting into fifth at such a low speed? The reason that it didn't grind at such a low rpm is because it doesn't have as much engine load on it.
xlee08
Honda Civic (2006 - 2015)
Aug 24, 2015 10:43 PM
SoCalian_SD
Jan 18, 2009 07:43 AM
smokedyou19
May 25, 2006 09:53 AM
homeslice0229
Sep 2, 2005 07:28 PM
bseries_beast
Jun 6, 2005 09:33 PM
