89-91 CRX w/ DOHC ZC trans... Use 93 integra axles and I-shaft?
Old Sep 17, 2005 | 10:47 PM
Ls1 FD3s's Avatar
Default 89-91 CRX w/ DOHC ZC trans... Use 93 integra axles and I-shaft?
Since i cant find a Si D-series trans to save my life. I am going to use a JDM ZC trans in my 90 DOHC ZC CRX Si hot rod. What axles do the trick? If i remember correctly you just use the 90-93 integra axles and intermediate shaft and life is gravy? Correct or no?
thanks to all that help!!!!
Old Sep 19, 2005 | 10:24 AM
Ls1 FD3s's Avatar
Default Re: 89-91 CRX w/ DOHC ZC trans... Use 93 integra axles and I-shaft? (Ls1 FD3s)
thanks guys.
Old Sep 19, 2005 | 04:04 PM
Ls1 FD3s's Avatar
or is it the 89 integra axles???
Old Oct 6, 2005 | 08:43 AM
hseriescivic's Avatar
I used the 94 integra axles in my 95 coupe. Im not sure what you would use in your crx but i would call hasport or Honda motors online and they will know for sure. I believe the intermediate shaft was acctually made with the zc. (not sure though)
Old Oct 6, 2005 | 11:46 AM
virginia_dude's Avatar
guys, guys........been there done that...trust me on this. uyou need 90-93 integra gsr non-abs axels..( a perfect fit)....and make sure you get the ZC intermediat shaft when you buy the trans....
Old Oct 6, 2005 | 02:04 PM
slomofo's Avatar
GDD Member
Did you say you're going to put a ZC trans on your A6 motor? If so, it won't work.
Old Oct 11, 2005 | 08:27 AM
DohcVtecCrx's Avatar
Default Re: (slomofo)
Why is that?
crxguy406
Nov 9, 2013 07:24 PM
jeffruby
Jul 12, 2006 06:45 AM
TH33G4MON3
10
Sep 11, 2005 02:30 PM
shivic
Aug 11, 2004 06:12 PM
dohcnotec
Jun 26, 2004 11:47 PM
