auto - manural, do i need a manual wiring harness? will a manual ecu fit a auto harness
Couple of questions:
I am currently buying parts for my auto to manual conversion. Pretty much got what is needed to make it work, but I was wondering if I needed these parts to make it work right.
1. Would a manual ECU obdII fit on my Auto obdII harness?
2. does the engine wiring harness off a manual intergra include the wiring for the clutch pedal and then leads into and plugs onto the tranny?
3. are the wiring harness different off a obd2 and obd1?
4. do I need the wiring harenss off a manual car?
Modified by oxymoron at 9:18 PM 9/17/2005
i would like to know also i just bought a p75 a05 obd2 and is there a conversion harness? cause only 2 out of 3 plugs plugs in.
You can use your auto ECU for the conversion but the check engine light will come on because of the tranny selenoid on the automatic. About the ecu plugs being different, I have never heard of? Make sure you are using the same OBD2 A for 94-98 and OBD2 B for 99-up. Hope this helps.
EKCivicGirl
Mar 21, 2011 06:58 PM
b20vtecEK
May 3, 2004 11:12 PM
NatedoggAZ
13
Nov 26, 2003 10:20 PM
