Cant get AXLE in
Old Sep 17, 2005 | 01:50 PM
stephen_civic98's Avatar
Default Cant get AXLE in
I just did a tranny and clutch repleace... on a stock d16y7 engine. its a 98civic DX.. Below are a bunch of photos. the problem is, getting the axle back into the tranny box.. i cant seem to get it in all the way.. any tips / help would be wonderful
thanks again guys!
-Stephen
AIM: Super Rand0m
Old Sep 17, 2005 | 01:53 PM
wwang924's Avatar
Default Re: Cant get AXLE in (stephen_civic98)
i just did the same thing, the axles actually went back in quite easily. But i did use a rubber hammer to just make sure everything was in snug.
Old Sep 17, 2005 | 01:54 PM
Mario.'s Avatar
Default Re: Cant get AXLE in (wwang924)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wwang924 &raquo;</TD></TR><TR><TD CLASS="quote">i just did the same thing, the axles actually went back in quite easily. But i did use a rubber hammer to just make sure everything was in snug. </TD></TR></TABLE>
Old Sep 17, 2005 | 01:55 PM
how did u hit it? Im am afred of doing damage to the axle....
Old Sep 17, 2005 | 01:58 PM
Hatch'd's Avatar
put the axle nut on the end and hit with the rubber mallet
Old Sep 17, 2005 | 01:59 PM
Farmer Brown's Avatar
Default Re: Cant get AXLE in (Hatch'd)
Just keep at it. It will pop back in.
Old Sep 17, 2005 | 02:16 PM
Default Re: Cant get AXLE in (Djaric)
i got it guys... the pass side was easy... after useing a 2x4 and a hammer.. the driverside was alot harder.... and it just didnt seem to go in as smooth... the driverside is a little bit more out then the pass side.. is this ok? i cant see the bar metal anymore on ether
Old Sep 17, 2005 | 05:23 PM
kKdARIAN's Avatar
Vice President/CEO
yup rubber mallot worked great for me'
Old Sep 17, 2005 | 05:34 PM
TorganFM.'s Avatar
Default Re: Cant get AXLE in (kKdARIAN)
I'd get a rubber footed C-Clamp or something to clamp onto the hub and then hammer it in with a more direct strike.
Old Sep 17, 2005 | 07:29 PM
DNB Creative . com's Avatar
the axle has a little clip by the splines that can keep it from sliding in, hardtoexplain but if you look at the clip as you slide it in youll see if its hung up and not letting the axle in.
Old Sep 17, 2005 | 07:51 PM
teamvirus's Avatar
My car breaks a lot!
Default Re: (DNB Creative . com)
get a hammer!
freshvibes
Nov 23, 2007 07:54 AM
BONGFIRE420
24
Oct 6, 2007 12:10 PM
Mavrick
Nov 11, 2005 10:04 AM
stealthhatch
Mar 21, 2004 09:20 AM
tecnic1
Jul 11, 2003 07:23 PM
