QUICK QUESTION
WELL THE SERVER IS DOWN SO I COULDNT SEARCH SORRY FOR ANY INCONVENIENCE IM GONNA CAUSE.... I HAVE A 93 LS MOTOR TRYING TO SWAP INTO MY LIL BROS SI CRX WANT TO KNOW IF ITS OBD1?? I WAS TOLD IT WAS OBD 0 SO I WAS JUST GONNA PLUG AND PLAY... BUT AFTER COMING INTO TOWN AND LOOKING AT THE MOTOR MY LIL BRO PURCHASE I BELIEVE ITS OBD 1 CAUSE THE HARNESS CLIPS DONT LOOK LIKE THERE GONNA PLUG AND PLAY... ANY HELP??? AND WILL ANY OTHER HARNESS WORK?? D SERIES SI HARNESS...
AND ANY OTHER GENERAL INFO ON THE SWAP WILL HELP THANXS
You can either keep the motor OBD1 and get an OBD0-OBD1 jumper harness, or use the CRX's harness and run it OBD0. If you go OBD0, you will need a 90-91 LS distributor and ECU. You can use the CRX's injectors on the LS motor too.
MADE MY DAY
