Swapping out doors, need help removing door mounted seat belt, window handle and lock...
Old Sep 17, 2005 | 11:22 AM
Blaze45's Avatar
Brrraaaap!
Default Swapping out doors, need help removing door mounted seat belt, window handle and lock...
I picked up a new door for my car cause I backed into a truck. So when I was taking the panel off n I pop'd off the window roller down handle and broke it (not the one I want to keep). I saw the little snap ring once I broke the handle off, but I want to know how to properly remove it without breaking it. I have no clue how to get the entire seatbelt assembly off eathier. I got the bottom part off with the 14mm bolts but how do I get the top part off? Any help would be sweet,
thanks
Blazed
Old Sep 17, 2005 | 05:17 PM
Slomo_civic's Avatar
its called a jesus clip. i think just some needle nose should get it off
Old Sep 17, 2005 | 07:57 PM
Crx Jimmy's Avatar
Default Re: (Slomo_civic)
they sell a $5 tool to remove the clip, also the upper portion of the belt you remove those T shaped round bolts at the top of the door they are a t45 or t47 torx i believe
PtownCivic
Jan 17, 2011 05:38 AM
Aquafina_Powered
Apr 25, 2006 03:29 PM
FernEF
Mar 22, 2006 06:49 AM
coot_er
Aug 12, 2004 08:03 AM
Civic138
May 21, 2004 08:38 AM
