Burnout w/ my launch controller always being on?
Old Sep 17, 2005 | 11:18 AM
trooper0641's Avatar
Default Burnout w/ my launch controller always being on?
Long story short, my ecu came with the launch control feature and its always on. It is set @ 4k...will I be able to do a burnout on wet pavement? Dont know, havent tried...dont want to break a axle. What do you guys do @ the track with a ecu that features the launch control crap to always be on?
Old Sep 17, 2005 | 01:32 PM
Redline130's Avatar
Default Re: Burnout w/ my launch controller always being on? (trooper0641)
If it's possible, I would turn it up (rpm wise), depending on your motor, 4K might not be enough to do a good burn out. I use my 2-step when I do a burn-out, it's set at 7400 or so (dependent upon track conditions). Hope this kinda answers your question.
Old Sep 17, 2005 | 01:43 PM
Billy T.'s Avatar
Default Re: Burnout w/ my launch controller always being on? (Redline130)
What do you mean by "always on?"
Does the car ever rev past 4k?
What ECU do you have?
Old Sep 17, 2005 | 02:09 PM
Drag_S14's Avatar
I would think the launch control would disengage as soon as it detects wheel speed, so you will just have to hope that the 4k launch will be enough to start a burnout without bogging.
Old Sep 17, 2005 | 03:33 PM
jgalaz1's Avatar
the launch control disengages as soon as you let off the clutch and the clutch swith is disengaged. If you don't have enough at 4K just turn it up a little, but you should be fine as 4k is around the rpm that most people launch at and get a little bit of wheel spin.
Mitchell Smith
Engine Management and Tuning
Apr 28, 2019 08:41 PM
fin781
Jul 23, 2007 08:46 PM
s10cky
Dec 5, 2006 05:08 PM
dkrex001
Nov 28, 2006 10:48 PM
CLE
Sep 11, 2006 10:06 AM
