DA integra - Fuel relay or Main relay???????
O.K. guys. Sometimes my car won't start like it's not getting fuel......and sometimes it's starts up right away....Has anyone had something like this???? I have no Check Engine Codes......
Does a fuel relay go bad??? or if the Main relay is going bad what kind of symptoms do I encounter....
This is an intermidant problem so it's hard to isolate being that it only happens once in awhile....but as of lately....it happens more frequently.......
I will crank the car..for a minute.........no motor start....then let it sit for another minute...and it cranks right up....The starter works fine.......I am either thinking it's something with the fuel system......fuel relay....or main relay....
Help>.................
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by og asr »</TD></TR><TR><TD CLASS="quote">......fuel relay....or main relay....
Are they not the same thing on an old acura? Have you checked the main fuel relay for cracked solder joints?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">
Are they not the same thing on an old acura? Have you checked the main fuel relay for cracked solder joints?</TD></TR></TABLE>
Where is this located?
it has nothing to do with soldering the joints and what not, you have a bad main fuel relay. for some reason g2s have that problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suckafuhreak »</TD></TR><TR><TD CLASS="quote">it has nothing to do with soldering the joints and what not, you have a bad main fuel relay.</TD></TR></TABLE>
Have you ever taken a close look at a bad one? They almost always have cracked solder joints.
Take a look at these links:
http://www.marklamond.co.uk/ho...y.htm
http://www.g2ic.com/forums/sho...y+fix
I had a similar problem this summer with my 1991 Integra. Hot weather seemed to be the initial cause. Removing the relay and re-soldering the joints took about 1/2 hour, and that was because I was working slowly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suckafuhreak »</TD></TR><TR><TD CLASS="quote">yeah but i'd rather replace the whole thing.</TD></TR></TABLE>
There is really no reason to spend the money on replacement when a free repair works perfectly well, in my opinion. If I recall, the relay costs $40-$50 new.
Mine has been perfect for 3-4 months now, and it didn't cost me a dime to fix.
i didnt buy my main relays brand new nor did i buy them at all . i collected them from junkyards. that's how i replaced mine. oh yeah hot weather sucks!
badtagz562
Feb 11, 2014 05:50 PM
Kidnkorner
Apr 4, 2010 08:54 PM
