I need an overdrive gear 5th gear 5500 rpms sucks help :(
Old Sep 17, 2005 | 06:05 AM
Stoich's Avatar
Default I need an overdrive gear 5th gear 5500 rpms sucks help :(
I love my new swap but on my 45 mile commute 5th gear at 5k sucks and its eating up my gas at a scary rate
WHat can i do about this? is it possible to swap in a taller 5th gear?
Old Sep 17, 2005 | 06:13 AM
kulangot's Avatar
Default Re: I need an overdrive gear 5th gear 5500 rpms sucks help :( (Stoich)
what transmission do you have? and its the final drive you want.
Old Sep 17, 2005 | 07:23 AM
Voodooboy520's Avatar
I'm thinking its a ZC transmission, they have a very short 5th. Read in the FAQ thread, theres a how-to in there about how to swap in a certain year integras 5th in there. I know you can swap in a Si 5th as well, not sure about the DX or HF though.
Old Sep 17, 2005 | 07:28 AM
SwissChEz82's Avatar
Default Re: (Voodooboy520)
How fast are you going??? I know at 5k in 5th on my ZC tranny I'm pushing 100mph.
Old Sep 17, 2005 | 09:25 AM
Mach69's Avatar
Default Re: (SwissChEz82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voodooboy520 &raquo;</TD></TR><TR><TD CLASS="quote">I'm thinking its a ZC transmission, they have a very short 5th. Read in the FAQ thread, theres a how-to in there about how to swap in a certain year integras 5th in there. I know you can swap in a Si 5th as well, not sure about the DX or HF though.</TD></TR></TABLE>
If it is a d-series transmission, the Si and DX gear ratios are the exact same, so it wouldn't matter (the difference between DX and Si is the final drive). Also, the Si and DX gears will probably not bring down his rpms in 5th all that much, I think. His best bet would be to swap in the Hf 5th gear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwissChEz82 &raquo;</TD></TR><TR><TD CLASS="quote">How fast are you going??? I know at 5k in 5th on my ZC tranny I'm pushing 100mph.</TD></TR></TABLE>
Thats about the same on my '89 Si transmission.
We need to know what transmission you have.
Old Sep 17, 2005 | 10:38 AM
Captn Shakelford.'s Avatar
Default Re: (Mach69)
j1 or s1 probally
Old Sep 17, 2005 | 11:04 AM
jisu009's Avatar
Default Re: (t3h WIN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t3h WIN &raquo;</TD></TR><TR><TD CLASS="quote">j1 or s1 probally</TD></TR></TABLE>
Then the answer is an LS 5th gear.
If it is a d series trans...might think about a HF gear in there.
Old Sep 17, 2005 | 12:35 PM
Default Re: (jisu009)
Anything HF is a bad idea, I'd go with an Si final drive.
Old Sep 17, 2005 | 12:50 PM
Burlyirishdude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwissChEz82 &raquo;</TD></TR><TR><TD CLASS="quote">Anything HF is a bad idea, I'd go with an Si final drive.</TD></TR></TABLE>
**** you the hf is the best....
No for sure the Hf 5th will be a good addition if you don't mind dropping down to 3k from the 4th gear----in a D series
In a b series----Cable: The Best is the 90-93 Ls 5th gear Hydro: I have not a lcue but i would guess any 5th out of the new civic tranny.
Old Sep 17, 2005 | 12:55 PM
drussell4801's Avatar
stoich, ignore everything else.
what transmission do you currently have?
Old Sep 17, 2005 | 06:13 PM
Stoich's Avatar
Default Re: I need an overdrive gear 5th gear 5500 rpms sucks help :( (drussell4801)
sorry for not giving that important info
Its a 00 Jdm ItR swap
not sure what the ratios are on the Jdm itr trans are.
Old Sep 17, 2005 | 07:43 PM
Crx Jimmy's Avatar
as posted earlier your best bet is a ls 5th
Old Sep 18, 2005 | 06:11 AM
Stoich's Avatar
Default Re: I need an overdrive gear 5th gear 5500 rpms sucks help :( (Crx Jimmy)
Any write ups on that?
Old Sep 21, 2005 | 04:34 PM
Default Re: (Burlyirishdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burlyirishdude &raquo;</TD></TR><TR><TD CLASS="quote">
In a b series----Cable: The Best is the 90-93 Ls 5th gear Hydro: I have not a lcue but i would guess any 5th out of the new civic tranny. </TD></TR></TABLE>
No **** you, you just answered your own question, why the hell would you want to drop from 7k in 4th down to 3k in 5th, you ******* rock.
Old Sep 21, 2005 | 05:17 PM
No **** you, you just answered your own question, why the hell would you want to drop from 7k in 4th down to 3k in 5th, you ******* rock.</TD></TR></TABLE>
in the quater mile, you probally wouldnt get out of 4th. so the only reason you would need to shift at a high rpm 4th to 5th is to street race which makes you a big fucktard,
so **** you
Old Sep 21, 2005 | 05:44 PM
Mr Synister's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stoich &raquo;</TD></TR><TR><TD CLASS="quote">Any write ups on that? </TD></TR></TABLE>
http://faq.ef-honda.com/index....ng=en
Try that, but it's an LS 5th gear for a S1 tranny. Pretty good write up with some pics on it. Hopefully it helps
92eghb
Transmission & Drivetrain
26
Apr 13, 2020 06:34 AM
bcp7272
Honda CR-V & Element
May 26, 2012 09:27 PM
Schurke
26
Apr 17, 2006 08:32 PM
biggdogg
13
Jan 15, 2005 05:08 PM
b17gsr
20
Nov 28, 2003 05:19 AM
