BFG drag radial PSI
Old Sep 17, 2005 | 05:21 AM
H22A_civic's Avatar
Default BFG drag radial PSI
I don't know if someone asked before but i tried the search and it's temporary unavailable.
I just got some used BFG w/rim and will be going to the track tomorrow. I wanted to know how much PSI i should put in them. they are currently at 12-13 PSI.
Old Sep 17, 2005 | 05:47 AM
mkinpwrat12g's's Avatar
Default Re: BFG drag radial PSI (H22A_civic)
that sounds about right
Old Sep 17, 2005 | 07:26 AM
hondaguyef's Avatar
Default Re: BFG drag radial PSI (blackpearlej8)
You just have test different pressures. Mine like to be at 9-10 psi. It also depends on the track as well. Start at 13-14psi and adjust from there.
Phil
Old Sep 17, 2005 | 08:06 AM
vaporboy12's Avatar
Default Re: BFG drag radial PSI (hondaguyef)
start at 14psi and air down till you find the sweet spot
Old Sep 18, 2005 | 09:07 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: BFG drag radial PSI (vaporboy12)
ran mine at 11psi last thurs got 1.9's with them...LS open diff
Old Sep 18, 2005 | 09:46 PM
kine462's Avatar
my 205-50-14's like 10 psi .....1.8 60ft ek coupe,sohc motor 5300 rpm 2step@8psi boost
SkRoMeEnIzANoNo
May 29, 2007 05:00 PM
curioso
Dec 7, 2005 04:07 PM
sircrxracer
Jun 13, 2004 02:40 PM
