Who makes the DOHC ZC parts? (searched)
Im just posting to see if anyone knows who makes the performance parts for the DOHC ZC ENGINE? If anyone knows please post.
P.S. i have heard different things bout the DOHC ZC swap (into 88 crx dx) and have read that i have to use integ. intermediate but ive also heard that if i use my same tranny ( Im Gonna ) that u dont have to use any axles or shafts, would someone plz set it straight for me on this.
thanks
thanks
intakes same as 88-91 civicz/crx with battery relocated u can use andy 92-00 civic one too
headers, any d-series with a lil port matching
tb is same as 88-9a crx/civics i think b series tbs work too
exhaust is same as ur car
cams are crespo, web,exospeed, jg, delta
cam gears are jg enginedynamics, and jun
clutches will be the same as ur tranny
and turbo kits are the same as any dseries kit just need to port match the mani
I did the DOHC ZC swap in my 90 crx si. I can shead some light for you. You have a dx? You will have to wire your main harrness for MPI since it is DPI now. You don't need the inetgra intermendeit unless you are using the ZC tranny otherwise any D-series tranny bolts right up. I am using my SI tranny. You will also need a downpipe from a 92+ civic ex..becuase the crx header is a 4-1 and the ZC uses a 4-2-1.
As far as performace check out http://www.theoldone.com I just ordered a set of roller wave pistons from them and they are awsome! JG makes cam gears. Also head over to..www.thezcr.com that is a GREAT reasource for ZC info!
Hope that helps you out if you have question ask away.
91GEDHATCH
Jul 15, 2014 06:05 AM
krysted9354
14
May 23, 2009 09:04 PM
88crxdxfastwhip
12
Sep 21, 2005 12:57 PM
h22_crx
Aug 30, 2005 05:59 AM
