Looking for a reliable tuner with dyno,anyone know a good place
Some where in the Orange Conty area. I need to get my car tuned. Just recently went to type R internals and cams. My compression is 230psi on all 4 cylander. I am detnating now and need to get my ECU tuned to the proper adjustment.
My Setup:
B18A1 block
LS rods and crank
Type R pistons
Type R oil pump and water pump
Type R cams
B16 head
LS injectors
NXL Direct Port NOS kit
P28 OBDI
B16 tranny with Type R LSD
Stage 2 Clutchnet clutch
My Setup:
B18A1 block
LS rods and crank
Type R pistons
Type R cams
B16 head
LS injectors
P28 OBDI
Trying to tune a factory stock Ecu? Not a whole lot to tune. Assuming you have cam gears and you want to tune fuel pressure,timing and the direct port, you can give these guyshttp://www.autolinkmotorworks.com a call. I heard they may not be tuning anymore so for a second choice you could call http://www.hookupsimporttek.com/services/. Both within a 50 mile radius to you I believe but not within the Orange curtian.
Goofnasty
Apr 22, 2015 03:25 AM
red_hatchback
Jun 18, 2005 05:13 AM
