ACT Clutch Problem
Old Sep 16, 2005 | 05:47 PM
TrojanMan01's Avatar
Default ACT Clutch Problem
Has any one ever experienced this problem.
i have a act 6 puck unsprung w/ extreme pressure plate
yesterday i was driving and i felt a pop in my clutch pedal i lost almost all pedal pressure but the clutch had alot of grab. i pulled over and no clutch fluid i didnt see any holes in the line so i felt under the clutch pedal. i noticed my clutch cylinder was shot. i put some fluid in it drove home and replaced the slave and tried bleeding the line over and over even w/ the pressure bleeder. but to no avail i had even less pressure than before. i tried adjusting the pedal and all. then i started the car and it drives fine no grinding in gears no clutch slip yet. so is my pressure plate junk now or what. i have had a couple of friends that own shops and or work at them tell me they think it is the pressure plate do to the noise comming from the tranny when the pedal is depressed. but the fork is moving everything fine..
if you have any ideas or had similar situations let me know please.
thanks guys
Old Sep 21, 2005 | 10:07 AM
bump
Vinde
Transmission & Drivetrain
Oct 30, 2014 08:14 AM
ohsojdmdc
Jul 30, 2014 08:37 AM
redline7
Feb 23, 2008 08:53 PM
RTW DC2R
Jun 23, 2006 07:42 AM
