S20 tranny? and what is a P07 ECU?
Old Sep 16, 2005 | 05:24 PM
A.S.I.M.O's Avatar
Default S20 tranny? and what is a P07 ECU?
what model of ecu is a P07? i got one with my d15b swap and instead of using that one i used my stock P28 from my d16z6. should i switch them or keep using the P28. i am not getting a codes and seems to be running fine. so should i not mess with a good thing, or switch. 2nd question is S20 tranny came with it. Does it have LSD?
thanks in advance
Old Sep 16, 2005 | 06:22 PM
SkoundrelUSA's Avatar
cute little bastard
Default Re: S20 tranny? and what is a P07 ECU? (EE GEE RYAN)
P07 is from a 92-95 Civic VX. Uhh an S80 tranny is from an Integra (DOHC) so its not gonna work with your SOHC...
Old Sep 16, 2005 | 06:28 PM
e jay one's Avatar
Default Re: S20 tranny? and what is a P07 ECU? (SkoundrelUSA)
he said s20. pm mistabone he knows his d series trannies.
Old Sep 16, 2005 | 06:35 PM
cute little bastard
Default Re: S20 tranny? and what is a P07 ECU? (e jay one)
Goddamn my glasses
Old Sep 16, 2005 | 06:40 PM
delslo93's Avatar
s20 tranny's are from all 92-95 civics/del sols. Theres another code on it that determines what model it is.
Old Sep 16, 2005 | 06:41 PM
delslo93's Avatar
Default Re: S20 tranny? and what is a P07 ECU? (delslo93)
Oh yeah...they will all work (d series S20's) but the one u want the most is the Si/Ex one. A lot better gearing
Old Sep 16, 2005 | 07:08 PM
A.S.I.M.O's Avatar
it is 97 SI tranny. at least that's what i was told. my question was this tranny have LSD or not. and will the P07 ecu be better than my P28?
Old Sep 16, 2005 | 07:13 PM
Relic1's Avatar
USDM/CDM S20 trannys did not come with LSD.
96+ trannies are S40 not S20.
Unless the car is from Canada there is no such thing as a 97 SI, if it is from Canada then it's the same as the EX here in the US.
the P07 uses a wideband O2 sensor, EGR valve and lean burn cruising to get better mileage.
Unless you have the VTEC-E version of the D15B you do not want the P07, stick to your P28.
Old Sep 16, 2005 | 07:18 PM
A.S.I.M.O's Avatar
Default Re: (Relic1)
how would i find out if it is vtec e?
BTW thanks for all the other tips that what i wanted to hear. and yes the car is from canada and i am sure it is a S20 tranny for sure.
Old Sep 16, 2005 | 08:29 PM
mike93eh
Guest
Posts: n/a
p08 is the d15b ecu and it will have LSD stamped on the tranny if it has lsd..
Old Sep 17, 2005 | 07:23 AM
Relic1's Avatar
Default Re: (EE GEE RYAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE GEE RYAN &raquo;</TD></TR><TR><TD CLASS="quote">how would i find out if it is vtec e?
BTW thanks for all the other tips that what i wanted to hear. and yes the car is from canada and i am sure it is a S20 tranny for sure.</TD></TR></TABLE>
check the case of the tranny it will have larger black letters LSD on it if it has LSD.
If the head code is P07 you have the VTEC-E engine
if the head code is P08 you have the VTEC version that is closest to the D16Z6.
about the D15B - - http://asia.vtec.net/article/d15b/
Old Sep 17, 2005 | 07:25 AM
lazie's Avatar
look on the block and you'll see what engine code is stamped on the block, D15Z1 is the engine code for all 92-95 civic VX's that came with the vtec-e
the tranny codes are A000 and B000 i'm pretty sure that you want the B000 thats from the ex/si dont quote me on this tho
Old Sep 17, 2005 | 07:29 AM
civic_driver's Avatar
the s20 is the jdm version of the p20... the dx has the A000 stamping and the ex/si have the B000 stamping on either s20/p20...essentially, s20 and p20 are the same transmission but the p20 is usdm
Old Sep 17, 2005 | 01:55 PM
A.S.I.M.O's Avatar
Default Re: (civic_driver)
thanks everyone
Old Sep 17, 2005 | 06:57 PM
FalkenSiR's Avatar
hey that's my avatar
civicStyle
Aug 1, 2011 02:12 PM
eg6_danny
Transmission & Drivetrain
Jan 17, 2011 07:07 PM
i_am_a_black_man
Mar 17, 2008 05:55 PM
speedKILLS
11
Feb 20, 2006 11:30 PM
ryanhook
15
Mar 15, 2004 11:24 AM
