Valve spring retainers - GSR vs ITR
Old Feb 28, 2002 | 09:16 AM
Grandprix's Avatar
Default Valve spring retainers - GSR vs ITR
Hello. My friend may have the oppurtunity of buying a used ITR valve train for his four-doh GSR. What parts should he all get. Cams of course, Valve Springs (his GSR has a lot of miles on it), but should he get the ITR retainers too? Are they any better than the GSR retainers??
He'll also be purchasing the Skunk2 Intake manifold, cam gears, and a chipped ECU. And from what I understand an ECU to get is P05 (CX), P06 (DX), and all OBD1 LS ECU's (PR4/P74/P75) ECU's that say 02D011F0-1500 can be chipped.
Anything else we should ask the itr owner for?
Old Feb 28, 2002 | 10:10 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: Valve spring retainers - GSR vs ITR (Grandprix)
Yep, get all the ITR stuff you can.
You need a P28 ecu. Any ecu can be chipped, but you need the right one.
Old Feb 28, 2002 | 10:30 AM
RyanR's Avatar
The retainers are the same on all the B-series VTEC engines.
Old Feb 28, 2002 | 04:15 PM
bojangs's Avatar
New User
don't bother with the retainers.. get the lma's!!
Old Feb 28, 2002 | 04:25 PM
Katman's Avatar
..put it this way.
Any non vtec OBD1 ECU with that part number can be converted to VTEC. I do them all the time. you got that info from my ecu section on jdmhondaparts, correct?
Old Feb 28, 2002 | 04:43 PM
akirajdmspec's Avatar
Default Re: Valve spring retainers - GSR vs ITR (Katman)
hey katman whens the new site going to be up and running?
Old Feb 28, 2002 | 08:58 PM
Grandprix's Avatar
..put it this way.
That would be an affirmative
Old Feb 28, 2002 | 09:00 PM
Grandprix's Avatar
Default Re: Valve spring retainers - GSR vs ITR (bojangs)
LMA? Lost Motion Assembly?? What the heck is it??
BTW Katman: That was a direct copy and paste from your site. I plagurized
Old Mar 1, 2002 | 10:02 PM
Quick 200k Mile Motor's Avatar
LMA = lost motion assembly; looks like a spring loaded tube with a 'nipple'; acts as a dampener for the vtec rocker (the thing that the Big lobe hits). A bad set of LMA's can make you think you need a valve adjustment.
4dooritr
Jan 4, 2005 09:11 PM
gsr squirrel
Jun 2, 2003 01:26 PM
b16powwer
Oct 20, 2002 10:49 PM
rsx03
Mar 27, 2002 06:59 PM
1fastGSR
Aug 19, 2001 09:13 PM
