Unorthodox
I have a 1994 honda Del Sol I swaped in a JDM B16a2 with LSD about 6 months ago I have a custom exhaust aem CAI with air bypass valve Nology plugs and wires Msd sci with blaster mas cap and coil an ACT xtreme pressure plate and 6 pad disc with a fidenza fly wheel among other mods but you get the idea the question is i want to get unorthodox pullies when i dont have power steering or AC I have heat though I want to know which pullies i would need for the altinator and crank i wanted to go single pully conversion just not sure which ones i would need thanx for the help
Unorthodox Racing's accessory pulleys do no under-drive like those from AEM and other manufacturers. They are simply lighter than the stock ones and intended to compliment the UR crank pulley. If you will already be running the UR crank pulley, your money would be much better spent elsewhere.
As for the crank pulley, go through UR's website and locate the pulley for a '94-'01 Integra or a '99-'00 Si.
tmekjian
Mar 31, 2003 12:19 PM
