RSX-S Brake Swap on 5th Gen?
RSX Type-S brakes are pretty big.......
I'm looking for a comparison between the Type-S calipers vs. 5th Gen's vs. NSX.........
Questions I have about the RSX-S calipers......
Are they twin piston or single? Specs?
How do they compare? (RSX-S vs. 5th Gen vs. NSX)
and ultimately....
Will they swap over to the prelude?
Thanks!
and ultimately....
Thanks!
The RSX is a single piston design, and no they will not be a straight swap. Just use the Legend/NSX twin piston caliper with some aggressive brake pads and call it a day. The RSX has an upgraded caliper which comes by way of the MDX, still more work than it's worth for a Lude. The Legend/NSX caliper is a straight swap for most Ludes, so that would make the most sense in terms of OEM brake upgrades.
FuNkDrSpOt
Oct 3, 2006 08:37 PM
