TO SHIM OR NOT TO SHIM??????
Old Sep 16, 2005 | 11:14 AM
Civiclized's Avatar
Default TO SHIM OR NOT TO SHIM??????
90 Civic DX,1.5L DPIM.
Doing head job,thought about using a shim with .020" thickness(thinner than factory replacement). But in my ignorant little world I need to know a couple things.
-Do you have to pull of the harmonic balacner(crank pulley) to take off the timming cover to reset the tensioner?
-If I shim it instead of shaving it with the given thickness of the shim, will my vavles get mashed up??
-will my timming be so severly off that it will flat out be worthless to atemp this???
MY CAR IS IN PIECES!!!PLEASE GIVE USEFUL FEED BACK!!!!
Old Sep 16, 2005 | 12:11 PM
DohcVtecCrx's Avatar
Default Re: TO SHIM OR NOT TO SHIM?????? (Civiclized)
there is a 14mm bolt that holds the tensioner and there is a nice little hole in the cover so no you do not need to take that off.
As far as the shim thing, I have no clue wtf your talking about.
Old Sep 16, 2005 | 12:19 PM
dr_latino999's Avatar
Default Re: TO SHIM OR NOT TO SHIM?????? (DohcVtecCrx)
Shim = Head gasket?
ellz
Honda Civic (2001 - 2005)
Sep 2, 2017 10:13 PM
mist sITR
Feb 20, 2008 09:39 PM
uberhaulin
Jul 5, 2006 05:36 PM
Paprika
Nov 3, 2004 07:04 PM
Austin
Jan 31, 2002 10:17 AM
