98 itr tranny on b16
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unclepowers »</TD></TR><TR><TD CLASS="quote">the same but better to get a close ratio 1600 box..even the b18 guys are tryin to get 1600 gearboxes not 1800 integra boxes....</TD></TR></TABLE>
ALL USDM IT-R and JDM 96-97 trannies have the same gear ratios as the JDM/USDM B16A trannies. the main advantage is the LSD standard in the IT-R tranny. the 98+ JDM IT-R has a the same gear ratios with a lower (numerically higher) final drive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6 SiRII »</TD></TR><TR><TD CLASS="quote">are you looking for a USDM or JDM 98 Spec ITR tranny? Have you ever consider installing a LSD for your B16A tranny?</TD></TR></TABLE>
good suggestion
good suggestion
.. no such thing.there are hydraulic and cable boxes...depending on the gears in it..u open it up count the number of teeth on it do some division and u calculate ur gear ratio..they DO NOT all have the same gear ratios...when we repair boxes we have match up the gears so the gear ratios match back up..
tomlinson619
25
Dec 14, 2012 11:08 AM
99SlammedCivic
Sep 18, 2005 01:43 PM
