my head unit is pissing me off!! pics inside
Old Sep 16, 2005 | 10:08 AM
civictyper96's Avatar
Default my head unit is pissing me off!! pics inside
no power out of sudden, the fuse in the engine was blow out, and i replace it. Still no power at all, dunno wut going on. anyone know how to remove the after market head unit?? help me please
Old Sep 16, 2005 | 10:29 AM
fcm's Avatar
fcm
Old Fart
Default Re: my head unit is pissing me off!! pics inside (civictyper96)
Remove the faceplate, remove the trim, if you do not have the "keys" you should be able to slide a thin knife, [like a dinner knife] down each side of the HU go here http://www.us.aiwa.com/default...l=420 click on English then scroll to page 16 all Aiwas should be the same. 94
Old Sep 16, 2005 | 10:36 AM
romoracing's Avatar
Default Re: my head unit is pissing me off!! pics inside (fcm)
look under the center console(pic 2) There should be 4 gold 8mm screws. Remove them then the whole climate control and radio should come out. Then check all the connections. Also if you have a computer power supply take out the harn. from the car(radio) splice the power the acc. and ground (yellow, red, black)into the power supply. then check if the hu will turn on. If not then its a blown hu. Hope that made sense!~
Old Sep 16, 2005 | 10:50 AM
Default Re: my head unit is pissing me off!! pics inside (romoracing)
thanx guys, i am gonna try it
Old Sep 16, 2005 | 11:09 AM
finally got the unit out, and the fuse on the unit blown? i though i've checked earlier. any way i put new fuse on there, and guess what, the back up fuse under the hood blown this time??? WTF
I've checked all the connection, nothing is wrong.
Old Sep 16, 2005 | 11:11 AM
it keep blowing out fuses
Old Sep 16, 2005 | 03:28 PM
romoracing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictyper96 &raquo;</TD></TR><TR><TD CLASS="quote">it keep blowing out fuses</TD></TR></TABLE>
Check out the wiring. See if there is any shorts, make sure all the connections are good, also check out the coloring of the wires. If there all good then most likly the hu is bad.
Old Sep 16, 2005 | 06:24 PM
i am sorry, can u tell me what is hu?
Old Sep 16, 2005 | 06:58 PM
romoracing's Avatar
sorry it stands for head unit
Old Sep 17, 2005 | 09:51 AM
fcm's Avatar
fcm
Old Fart
romoracing is correct, you have a problem with wiring or there is a problem with the HU itself, if the fuse under the hood only blows when you turn up the volume, you may just be under-powering the HU, you may have to run a power wire from the batt. to the HUs constant power, [yellow], if the fuse blows even at lower volumes, but after it's been on for a bit, that is most likely a shorted out speaker output, [minor short on one or more of the speakers/speaker leads] if the fuse blows as soon as you put it in or as soon as you turn the HU on, that can still be shorted out speakers/speaker leads, [dead short] or more then likely the outputs on the HU are blown.
To narrow down the problem you really need a multimeter so you can check the speakers and leads behind the HU, check for continuity to ground, [there should be non] continuity between any sets, [pos. and neg.] of leads, and that you have continuity/resistance between a speakers pos. and neg. lead, [measured in ohms] and that should be in most cases 4 ohms, [it may read a little more or less then 4ohm] here is your cars oem wire colors http://www.installdr.com/Harnesses/HA-Wiring.pdf use this to make sure you have it wired properly, check and make sure there are no bare connections, [shorts] no wires getting "pinched" under the back of the HU when you push the unit in.
If you don't have or can't borrow a multimeter, try this, disconnect all the speaker leads from the HU, make sure the speaker leads coming from the HU can't short out to anything, [including themselves] see if the fuse still blows, if it does, the problem is in the HU, if it does not, then more then likely the problem is a short, [speaker or speaker wiring] or miswiring. 94
Old Sep 17, 2005 | 02:30 PM
thank you so much for the complete detail write up
Old Sep 17, 2005 | 04:50 PM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
There's your problem right there..
Old Sep 17, 2005 | 11:15 PM
Default Re: my head unit is pissing me off!! pics inside (ScareyH22A)
yeah i notice that,
thats way i am thinking about to get a alpine
Old Sep 18, 2005 | 07:12 AM
romoracing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictyper96 &raquo;</TD></TR><TR><TD CLASS="quote">yeah i notice that,
thats way i am thinking about to get a alpine</TD></TR></TABLE>
Im crazy about alpine. But if your going to put an amp and are looking to say some money then i would look into a pioneer. Pioneer has a higher output then alpine does. Its sound quailty is also pretty good. Alpine is alittle more money wise but the sound quailty is the best(Imo) also if you get a high enough model (cda-9855 and up) they have a i-personlize feature were you go to alpines site and make a eq for it. But with alpine like i stated above you dont get the power on the outputs.
*Im just trying to show you another option then alpine.
Old Sep 18, 2005 | 07:51 AM
i c, thanx
Old Sep 18, 2005 | 05:33 PM
i have checked everything, all the grounding, and all the connection. and i was just like f**k it, i am just gonna get a new hu. so i went and pick up a new hu and now it is working perfectly. i guess it was a bad hu after all. thanx for you guys' help anyway.
Old Sep 18, 2005 | 07:00 PM
shyboy817's Avatar
My sister used to have that cd player..that thing sucked imo. Get a new one, that one takes a long time to change tracks for data cd's.
Old Sep 18, 2005 | 07:04 PM
Default Re: (shyboy817)
installed this one in my car this afternoon, this is all i can afford right now, and i like it. its much more powerful then my old aiwa.
Old Sep 18, 2005 | 07:05 PM
shyboy817's Avatar
So is everything working fine now?
Old Sep 18, 2005 | 07:40 PM
everything is working perfectly
Old Sep 18, 2005 | 08:02 PM
romoracing's Avatar
Default Re: (civictyper96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictyper96 &raquo;</TD></TR><TR><TD CLASS="quote">everything is working perfectly</TD></TR></TABLE>
Glad to hear that!!!
Old Sep 19, 2005 | 12:16 PM
customgsr's Avatar
On pulling an aftermarket radio out you could have used a set of radio keys to push in on the sides of the radio and it will unlock the tabs that are holding the radio in its cage. I hated doing radios in those hondas. They are a pain in the ***. There is a back bracket in the back of the unit held on with a 8mm bolt I think check to see if that is the problem.
Old Sep 19, 2005 | 04:06 PM
Default Re: my head unit is pissing me off!! pics inside (customgsr)
yuuup....
Whatislove
Honda Civic (2001 - 2005)
Jun 19, 2010 12:45 PM
93allmotorcoupe
Audio / Security / Video
Mar 17, 2006 08:43 AM
texasnick
Jan 25, 2005 11:06 PM
r0nnie
Nov 4, 2003 12:41 PM
