Removing Oil Squirters -- b18c1
was wondering the good and bad about doing this. I actually got this motor back from the machine shop and found they stripped out one of the squirters totally. So i was thinking about blocking them off. Let me know if anyone has had experience in this.
This motor:
b18c1 .25mm over CTR pistons
Decked Block
balanced
stock rods/bolts
ported head
skunk2 stg 2 cams, skunk2 hardware
This motor:
Decked Block
balanced
stock rods/bolts
ported head
well they don't make a heli coil fine enough to fix this one squirter.
I know there are people out there that have done this...
block em off
the machine shop didnt **** it, unless they were the ones unscreweing/screwing them in (i dunno why u woudlnt have pulled them out yourself.
if they did, make them weld all fo them for you
i just got my block back from howard rlz enginering most amazing work i ever saw guys its nice but anyways my oil squirters were blocked off now with a plug on my block
Well, my guy is going to heli coil them and i'll reuse them.
They were taken out initially to be cleaned while flushing the block. I believe it was the last guy that put this motor together that screwed them up.
Tell me why you block them off...
take a close lok at your oiling system, and where oil starts/ends. u will see why its good in some isntances to block them.
i have also heared of huge reduction in oil temps by blocking them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnzm »</TD></TR><TR><TD CLASS="quote">take a close lok at your oiling system, and where oil starts/ends. u will see why its good in some isntances to block them.
i have also heared of huge reduction in oil temps by blocking them.</TD></TR></TABLE>
...which would make sense, considering that they were designed to cool the pistons.
ITR-00-1457
Jun 2, 2004 12:21 PM
