what's up with this?? TPS sensor on a 99 GSR problems
so a friend and i were working on another friends 99 GSR (aoiformula on this bord) he had a CEL throwing the TPS sensor code. he got another TPS sensor off of a OBD 1 LS throttle body. we changed that out, calibrated it right (i'll get to that in a sec) and now when we start the car even when it's warm, it idel's at about 1100rpm, then at WOT the car bogs and dies. now giving it 1/2 throttle, the car will only rev to about 3000rpm then bogs right down to 1000rpm, and now the CEL won't even come on.
as for calibrating the TPS, the helms says to calibrate for 44 or 45 i think. with a voltage tester set at 9v it read 56. then we tested my other friends OBD 1 GSR, his reading was 26, then we tested my OBD 1 LS and it read 25. i'm absoulty **** out of ideas that could be wrong. any help would be appreciated.
dohcem1
19
Jun 1, 2009 09:35 PM
ZoobeaR
Jun 17, 2002 04:41 PM
