sawp question..again :(
my car: 92 "S" model lude
i did a f22 to jdm h22 swap
the plug that goes onto the injector has power to it but isnt working fully...the diagnostic basically showed i was runnning only 3 cylnders... # 1 3 and 4.. i hear the spark from the cylnder but im guessing theres no gas but just a spark....did a compresion check, compression is good on all four......i switched the injectors around to see if it was a faulty injector but they all worked in different cylnders...its weird... do i have to go back and check the wiring for a break or can i just ground it somewhere else??? cause im guessing its a wiring problem ( hoping actually)??
i talked to a friend and he said he had the same problem when he ran hondata on his ecu and too find out the ecu was bad
...i dont what **** is going on..i hope its not the ecu...i mean i got this **** from HMO (hondamotorsonline) because of their reputation....ill check the resistor box also...#2 is just not firing, like u can hear a spark but when you pull the rubber spark plug boot it doesnt bog down unlike all the others when you pull the rubber plug it bogs down....
baonest
Dec 6, 2013 12:36 PM
BIG RICH
Sep 16, 2006 11:55 AM
