Eagle Rods w/OEM pistons????
I posted a thread in the all motor forum also......Basically I'm trying to find out if ITR pistons will work with Eagle rods....I came across a thread that said CTR pistons won't work....So I 'm wondering if ITR's will work....
[URL] https://honda-tech.com/zerothread?id=1319304[/URL]
Yes it will work. But you have to Modify your CTR , ITR pistons. You have to add grooves on the piston in the Wrist Pin hole for the Clips. And they will work. A machine shop can do it or Contact JE pistons they do it as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITAIntegraLS »</TD></TR><TR><TD CLASS="quote">Yes it will work. But you have to Modify your CTR , ITR pistons. You have to add grooves on the piston in the Wrist Pin hole for the Clips. And they will work. A machine shop can do it or Contact JE pistons they do it as well.</TD></TR></TABLE>
Most forged rods are designed to use clips to hold the wrist pins (which most aftermarket forged pistons are designed for) whereas the factory cast piston is designed for a press fit type wrist pin fit.
JMinSi2000
Aug 28, 2003 01:51 PM
