noise problem from the wheel
Old Sep 15, 2005 | 05:58 PM
EJ8CIVIC's Avatar
Default noise problem from the wheel
i got a scraping noise coming from the wheel rear driver side
it sounds like the rear shock is lose but its not
can ne1 help me out in findn the problem
Old Sep 16, 2005 | 01:45 AM
XrcR6's Avatar
Default Re: noise problem from the wheel (98exdream)
Pretty vague there, is there a certain time/occasion this happens? (only braking, only backing up, all the time, only certain speeds, etc.)
Could be any number of things...wheel bearing going, rock stuck in the caliper/rotor interface, a wheel weight coming loose and rubbing on the dust shield, etc...
Get out the oem jack, lift that corner of the car and spin the wheel by hand (parking brake off). You'll probably be able to narrow it down much quicker with eyes and ears a foot away from the area.
Old Sep 16, 2005 | 07:16 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: noise problem from the wheel (XrcR6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XrcR6 &raquo;</TD></TR><TR><TD CLASS="quote">Could be any number of things...wheel bearing going, rock stuck in the caliper/rotor interface, a wheel weight coming loose and rubbing on the dust shield, etc...</TD></TR></TABLE>
...brake pads may need replacing, splash shields got bent, ...
Stopsign32v
Apr 30, 2018 06:30 PM
theguy22
May 3, 2012 06:33 PM
7thGenAccord
Dec 11, 2005 06:11 PM
turboteg96
May 10, 2005 10:28 AM
01blackgsr
Apr 17, 2005 12:46 PM
