balance belt pulley and retainer clip
1) where in this pic does the retainer clip go??? the one i have is from honda tha tis shaped like an n with two bolt holes at the top
2) it's hard to see in the pic, but when i put the balancer belt pulley back on, it is loose, if looking at it from the side so the pulley looks like an l , i can wobble it back and forth so it looks like / and \ , is that normal and it will just tighten back up when i put the adjuster nut back on???
thanks
Modified by buffalo wings at 6:45 PM 9/15/2005
Its the balance shaft seal retainer, goes on the balance shaft seen in your pic. See the two holes right above the balance shaft, you cant miss it . .
o
o
backinblue92
Feb 27, 2015 09:57 AM
