Toda Spec C upgrade
I am upgrading from spec B's to spec C's in my R. I already have a toda valve spring and cam gear and CTR pistons in my R. I was just wondering if anyone knew the clearances on the Spec C's. I have been told just to install at TDC and I will be fine..... but I am contacting toda tomorrow with my own questions.
correct. i had the ctr pistons on my itr block and toda C cam and there is no issue with clearance. I also have a ls vtec with ctr pistons and toda c cam as well, you will be fine! you don't need much adjustment anyway with Toda cams , one or two degrees each way is all you need
hybridsedan
May 23, 2003 04:29 AM
