What size will fit?
Old Sep 15, 2005 | 03:11 PM
91 Civic B16's Avatar
Default What size will fit?
I tried searching, but no luck. My hatch is lowered 2" on eibach springs. Will a 17x7" rim fit in the wheel well? If so, what tires should I run. Im partial to Nitto tires. Would 40 series be ok? Would 30 series work better with no rub? Thanks in advance.
Old Sep 15, 2005 | 03:16 PM
Suck my DX's Avatar
Default Re: What size will fit? (91 Civic B16)
u might rub but 2 inches is not that bad of a drop...u should be fine
Old Sep 15, 2005 | 03:52 PM
Autoworks's Avatar
Ther's not a 30 series. Shortest tire I've ever sold or even seen is a 215/35-17. A 205/40-17 should fit fine
Old Sep 15, 2005 | 05:13 PM
88backhatch's Avatar
Default Re: What size will fit? (Autoworks)
i drop my efhatch 3''s in tha back on my 17's and i still got about and inch and im runnin 205/40's, note 205's will not tuck with good camber, 195 is about as close as they'll get
Old Sep 15, 2005 | 05:23 PM
turbob16ef's Avatar
From: if you build it they will come, the bottom carolina, duh
my hatch is lowered about 2.5 on sportline srings and the only time that they rub is when you are turning and going up a hill ir driveway. i have had it dropped 4 in all the way around and pretty much the same thing, that is with the wheel tuckin.
Old Sep 15, 2005 | 06:17 PM
vw eater's Avatar
Default Re: What size will fit? (turbob16EF)
mine rubs crazy...i wouldent go w/17's
Southpaw.
May 29, 2010 06:57 AM
dot.org
Aug 27, 2008 08:23 AM
brknlude
Apr 10, 2003 01:09 PM
DeLiRiOu5
Oct 30, 2002 10:56 AM
