Steering column
Old Sep 15, 2005 | 02:14 PM
ntensehonda's Avatar
Default Steering column
Squeaking when I turn the wheel...I've owned 3 EG hatches and they've all done it...usually more so when it's cold out...
What is this and what's the fix?
Old Sep 15, 2005 | 06:34 PM
Default Re: Steering column (ntensehonda)
Anyone?
Old Sep 30, 2005 | 09:36 PM
Seriously, can nobody answer this question...
Old Oct 7, 2005 | 04:50 AM
up for an answer
Old Oct 7, 2005 | 05:02 AM
monicle's Avatar
I know what you mean but i dont know what it is. sorry. bump
Old Oct 7, 2005 | 10:37 PM
Default Re: Steering column (monicle)
well thanks for the bump...I'm just wanting to know how I can cure the problem
I figure it's maybe the boot down on the column or something, but whenever it actually does it, I don't have time to go searching for the noise.
Modified by ntensehonda at 10:26 PM 10/10/2005
Old Oct 7, 2005 | 10:45 PM
Kendall's Avatar
Not really an answer to your question, but it doesn't sound like anything a can of WD-40 couldn't fix.
Old Oct 7, 2005 | 11:41 PM
E.Honda's Avatar
You would think that if you have had 3 of them do it, you would not be so lazy and find out for yourself.
Old Oct 10, 2005 | 07:25 PM
Default Re: Steering column (E.Honda)
Thanks for calling me lazy, but I thought that perhaps if someone else has gone through this and diagnosed the problem, then perhaps I won't have to take time out of my day managing a store to tear into it myself. Isn't that what this forum was created for, or am I mistaken? I was under the impression that H-T was here for people to help other people and share things about their cars...maybe I just assumed too much...
NOW, does anyone with the intelligence higher than a sack of potatoes have an answer for me, or does nobody know what actually causes this?
Old Oct 10, 2005 | 09:09 PM
civic_driver's Avatar
the fix is a bag of cocaine, as a friend used to say :/
ntense, could you post the solution once you figure it out?
thanks man!
Old Oct 10, 2005 | 09:12 PM
handa's Avatar
Default Re: (civic_driver)
bump this up.
my steering column clicks when i turn the wheel back and forth...could be related to boot joints.
Old Oct 10, 2005 | 09:36 PM
handa, like your mixes.. nice
Old Oct 10, 2005 | 10:26 PM
Default Re: (handa)
handa,
The clockspring for your airbag is loose...that's what the clickingis all about. Unless you know very well what you're doing, you should take it to a professional to get it fixed.
Old Oct 11, 2005 | 02:30 PM
still lookin for an answer
Old Oct 11, 2005 | 02:39 PM
my_slow_civic's Avatar
Try putting a little grease on the knuckle, half way or so down the column.
Old Oct 11, 2005 | 03:00 PM
Default Re: (my_slow_civic)
eh, that sounds like a plan, but I think that it's related to something a little higher up in the column...
Old Oct 11, 2005 | 04:47 PM
dpkelly's Avatar
Default Re: (ntensehonda)
If it's higher up, it's the contact for the horn. I know this cause my horn quit working when I thought I "fixed" it.
If you try oiling it, your horn will probably not sound as loud. Just grin and bear it.
Old Oct 11, 2005 | 09:38 PM
Default Re: (dpkelly)
That's a new one...perhaps I should use some lithium grease...that should be what's in there from the factory....good call
Old Oct 11, 2005 | 11:02 PM
_HANS's Avatar
From: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
when i had my EG's i saw it was just the back of the steering wheel rubbin on the column cover? mine was just minimal rub from that. dunno how serious yours rubs?
Old Oct 12, 2005 | 05:14 AM
dpkelly's Avatar
You just have to remove the upper and lower covers to see it (very simple fix).
Old Oct 12, 2005 | 05:22 AM
robbieshonda's Avatar
kendell is dead on with wd40. its an NC Thing
J_Roc41
Jan 30, 2009 08:35 PM
cbp_crx
Feb 7, 2006 02:34 PM
HATCHingMN
Nov 9, 2005 08:36 PM
ITR0950
Jan 2, 2005 09:21 PM
RiCE On IcE 2
Dec 20, 2002 12:43 PM
