lift points on my CRX
OK, I already did a search for 'lift points', 'jack points', etc. etc. I came up empty handed for CRX lift points so I'm making this post. I realize there are square cutout locations just behind the front tires and just ahead of the rear tires on the car. These can be used as jack points when leaving the car on jack stands. However, the metal rim that comprises these lift locations bends with use and I'm afraid to use a jack stand on these parts of the car for fear that I might bend something. Can someone actually post pics of locations under their car that they use to lift the car with a jack stand? I realize this is a stupid noob question, if it has been answered elsewhere I apologize.
The reinforced areas behind, and ahead of the rear tires (like you mentioned). Then there's a square area on the front crossmember that you can use to lift the whole front. And then the towhook is another area for the rear.
MilanoRex
10
Mar 9, 2002 11:44 PM
