best spool performance for your b16a
which turbo spools up hardest for a built motor for the range of 500-600 hp?? if u need more info on specs, ill post it up in a bit cuz im at work right now.. but i was wondering what would come close to the performance of the gt35R? would the t3/.67 be a good choice? note: will be revving up to 9500 if that would help.
set up:
b16a
sleeves
edelbrock intake mani
pistons ... possible overbore but havent decided
rods
255 fuel pump
1000 cc injectors
hondata s200 boost
complete valvetrain
type r cams
cam gears
type r lsd tranny
and so far still deciding what turbo to change to, so far im using a t3/t04e and its living its last moments of life. any help would be appreciated as to what turbo would be good for this range. thanks fellaz
set up:
b16a
sleeves
rods
255 fuel pump
1000 cc injectors
hondata s200 boost
complete valvetrain
type r cams
cam gears
type r lsd tranny
