LS Cable Transmission Question????????
Old Sep 15, 2005 | 10:41 AM
Turbo R's Avatar
Default LS Cable Transmission Question????????
I put an LS motor in a crx and i am trying to put the passenger side axle in but it wont go in all the way. im using a 90 integra axle by the way.
I found out why. There is a Metal rod inside transmission where you put the axle through. That is what is stopping it from going in i believe. i know all trannys have that.
how do i get this axle to go in all the way!!!!!!!?????
please i need help now
Modified by Turbo R at 3:13 PM 9/15/2005
Modified by Turbo R at 3:17 PM 9/15/2005
Old Sep 15, 2005 | 11:13 AM
Turbo R's Avatar
Default Re: LS Cable Transmission Question???????? (Turbo R)
help
Old Sep 16, 2005 | 10:42 AM
tgreaves's Avatar
I think your refering to the pegleg for the open diff.. If so then thats suppose to be there..
Did you make sure the splines on your axles arent messed up.. Also try tapping it a little with a hammer..
RSRCliqueCRX
Nov 5, 2012 05:08 PM
6KAOS6
Nov 26, 2007 04:15 PM
stackz
Sep 28, 2006 02:34 PM
Turbo R
18
Sep 17, 2005 11:30 PM
digitalhav0c
May 6, 2002 05:24 AM
