Oil spitting out after turbo setup
Old Sep 15, 2005 | 09:05 AM
JDMbolo's Avatar
Default Oil spitting out after turbo setup
I got a question for u guys i just boosted my DA its been 2 weeks its been good except i need an O2 sensor and OIL is spitting out near the valve cover towards the top left where people usually put the aftermarket breathers(the small little intake filter looking things). Should i just clog up that hole or put one of those breathers on?
Old Sep 15, 2005 | 09:09 AM
low430's Avatar
Default Re: Oil spitting out after turbo setup (JDMbolo)
put a breather on, check your blowby Turbos usually leak oil around the turbo into the intake but If its leaking at the valve cover from assumption Id think its Blowby pushing the oil past the valve cover seal, Check and see if its the fitting leaking or the valve cover.
Carefull when checking blowby it may be REAL messy
Old Sep 15, 2005 | 05:10 PM
yee SERIOUS's Avatar
get a breather or make catch can setup
Old Sep 17, 2005 | 11:35 AM
JDMbolo's Avatar
alright thanx guys
Old Sep 17, 2005 | 11:48 AM
JDM-EJ1's Avatar
Default Re: (LiTtOGPiMp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LiTtOGPiMp &raquo;</TD></TR><TR><TD CLASS="quote">get a breather or make catch can setup</TD></TR></TABLE>
Old Sep 17, 2005 | 04:41 PM
lzylst's Avatar
+1 on the catch can. With the breather /filter things will get real messy under the hood.
Old Sep 17, 2005 | 04:57 PM
Johnny_Rocket's Avatar
Default Re: (lzylst)
sounds like blow by... I had the same thing happen on my turbo DA and when i pulled the pistons out pieces of ringlands fell on the ground It was the saddest thing I've ever seen
kiryl501
Jun 5, 2019 07:33 PM
UNDER PRESSURE
10
Oct 1, 2003 07:25 AM
nerdsports
May 10, 2003 11:47 AM
