Not running very fast......
Ok i have a 1994 turbo LS. Im running a t3/t4 turbo at around 9 lbs.(.6 bar) I run into a problem when I'm goin down the track. I just took it to norwalk last night and it ran a best of 15.1 at 97.8 mph. Now i bogged off the line a little bit but I'm guessing with 9 lbs. I should be running faster then that. My guess is the clutch. I have a brand new clutch at home that I'm going to replace it with but does anybody think it could be anything else. Also I dont hit full boost until about 5K rpm. Could it be just too much turbo lag? I really would like to know? Thanks for any help.
Driver
, Get a BOV and PReboost before you launch
Clutch like you said will have to be replaced.
Launching in my turbo Celica I would Rev the engine up let the RPM dip to 3 Feather the clutch real quick as you bring the rpm back up but AWD celica is different then FWD integra
Ahh I miss my IMSA
Counteract teh turbo lag
, Get a BOV and PReboost before you launchClutch like you said will have to be replaced.
Ahh I miss my IMSA
That trap speed is definitely not consistent with your times. Just by the sound of it you need to get that thing going a little harder. I'm sure if you can get out of the hole you can drop a second off that ET and probably pick up a couple miles per hour.
*Boostwerks*
21
Jun 14, 2002 03:25 PM
92HB_HB
Apr 17, 2002 05:49 PM
