is there any higher rated speedometer
Old Feb 28, 2002 | 12:08 AM
austrian type-R's Avatar
Default is there any higher rated speedometer
I wonder if there is a higher rated speedo. The stock one goes up to 270 kp/h and I want one which go up to 300 or so.
Old Feb 28, 2002 | 12:30 AM
DutchITR1689's Avatar
Default Re: is there any higher rated speedometer (austrian type-R)
Hahaha! You're kidding, right? Do you really think your ITR can go 300 km/h??!?!
Old Feb 28, 2002 | 12:45 AM
SoCal ITR's Avatar
Default Re: is there any higher rated speedometer (EuroITR1689)
Under lots of boost? I think so.
Old Feb 28, 2002 | 12:58 AM
Tommy_Gunns's Avatar
Default Re: is there any higher rated speedometer (SoCal ITR)
Isn't it limited by the gearing? I mean at 300 km/h it, would be revving at incredible speeds.
Old Feb 28, 2002 | 01:16 AM
With the stock Euro 5th gear and final gear you'll have to rev 10500 rpm and maintain engine power output at that rpm to reach 300 km/h on the speedo (not real speed)......
BTW you'll need a different tach that goes to 11000 rpm!! (SPOON?!?!)
[Modified by EuroITR1689, 11:28 AM 2/28/2002]
Old Feb 28, 2002 | 01:19 AM
typealex2's Avatar
If you are looking at your speedo at those speeds(not atainable by the way) perhaps you would be better off using the money to buy some driving lessons or some more crack.
Old Feb 28, 2002 | 02:08 AM
Default Re: is there any higher rated speedometer (typealex2)
I have orderd me a used USDM final drive (4.400) and in combo with my JDM 5th gear I can run 286 km/h @ 9200rpm with my 225/40/16 tires (diameter ~590 mm)
check it when you are a non-believer!!!!!!!!!!!!!! http://www.osella.com.au/java-gear-ratios-3.htm
[Modified by austrian type-R, 12:09 PM 2/28/2002]
Old Feb 28, 2002 | 02:15 AM
SoCal ITR's Avatar
I was just thinking of Sgt, I think he revs to about that.
Old Feb 28, 2002 | 02:39 AM
typealex2:
Do you know that in Europe we have no Speed limits on the German Autobahn. Driving 1 hour at 230-240 kph is boring. Plus I think with a longer gearing in the first 3 gears it helps me in acceleration, cause I can built more boost, caue the turbo gets more engine load and traction is a huge problem on high hp equipped fwd cars. So longer gearing has 2 positive sides in my opinion.
Old Feb 28, 2002 | 03:25 AM
Do you think or know whether your engine will produce enough power at 9200 rpm to reach 286 km/h? I think you need 350 hp @ 9200 rpm for it.
A turbo charged engine normally produce its max power at low rpms....
Old Feb 28, 2002 | 03:34 AM
Not with a T04e/T3 turbine :D This turbo is the perfect baby for the high reving Honda engines. I have no doubt that I´ll produce 350hp. Hell I will boost more than 1 Bar on 9:1 cr
Old Feb 28, 2002 | 03:38 AM
350 hp at what rpm? High overlap Type R cams are not ideal for Turbo.....
Old Feb 28, 2002 | 03:44 AM
No, Turbo loves the stock ITR camshafts...........I have cam gears too.
This is like my setup (DRAG III) with minor different. Also 9:1 cr..........not a big deal on turbo lag and power up in the sky :D
[Modified by austrian type-R, 1:44 PM 2/28/2002]
Old Feb 28, 2002 | 03:52 AM
The max power on the graph is reached at 8000 rpm and it's dropping very fast after 8100 rpm. I really doubt you will maintain 350 hp at 9200 for a topspeed of 286 km/h...
260 km/h top speed sounds more realistic.... Just my 2 Eurocents...
Old Feb 28, 2002 | 03:55 AM
it looks more to me, that the throttle is closed suddenly at 8100.
Old Feb 28, 2002 | 04:02 AM
A smaler turbo like mine, it is only a T3/T4 at 1.5 Bar on a b18C1 engine. Enough in my eyes power for 290khp.
Bigger turbo = more power at top end
Old Feb 28, 2002 | 04:06 AM
done's Avatar
why not get a ls tranny, those are longer gearing
Old Feb 28, 2002 | 04:07 AM
Default Re: is there any higher rated speedometer (Jordo)
harder to get for me and it is for sure expensiver. I got a 4.400 onyl used for 3000 miles fd for 100USD. And I ´ve heard that a LS tranny supports no LSD or so.
Old Feb 28, 2002 | 05:06 AM
Default Re: is there any higher rated speedometer (George Knighton)
I hate to be the spoil sport, but I really, honestly do not think the ITR bodywork is stable at 185 miles per hour!
You mean like WARP 10 (Hull integrity) in Star Trek?
Old Feb 28, 2002 | 05:19 AM
Perhaps my big doubledeck carbon adjustable wing on the trunck and some little wings on the frontpumper are useful .
Old Feb 28, 2002 | 05:28 AM
Dr Pooface's Avatar
Austrian Type-R: You sir are one crazy SOB. Get us a vid of you doing an autobahn run at 180 when you've got the parts installed.
Old Feb 28, 2002 | 05:33 AM
Default Re: is there any higher rated speedometer (Dr Pooface)
When the days are comming when my USD fd is in, I´ll make some pics of a speedo that stays (after 360 degree turn) @ 0 again. LOL!!!!!!!!!!!!!!!!!
Perhaps some bonus pic when I kick some Porsches azz!
hondacrx2
14
Jul 27, 2011 04:40 PM
jdmspoonitr
May 12, 2005 02:37 PM
black2001ITR
Mar 10, 2004 04:17 PM
Chemicalviper
Oct 21, 2003 10:23 PM
jonas
Jun 6, 2002 11:51 AM
