K20 into EK?
Old Sep 15, 2005 | 12:12 AM
spydog's Avatar
Default K20 into EK?
I searched and didnt find anything about this in this forum so I was wondering if anybody out there has a K20A or A2 or A3 or the '05 RSX Type S (i forgot the engine code for that one) engine swapped into their 1996-2000 Honda Civic hatchback? If so, was the swap hard? Does the engine fit well? Any problems with wiring? Have you gotten it smogged? So many questions... I am taking auto shop classes and I want to do the swap myself... I just need some real wisdom from people who have done it or worked on it! Thank you! btw I drive a 1996 Civic CX... sweet
Old Sep 15, 2005 | 04:28 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: K20 into EK? (spydog)
k20a.org is your best bet for exact detail of everything needed but here is a brief overview.
Overall, the swap is not 'hard', it's just alot of custom work.
After you pull your old motor and exhaust you will need to prep your engine bay by drilling out the passenger side mount bracket to make way for the new mounts:
You'll need to relocate the radiator to the other side by removing the rad brackets and welding them to the other side and removing the AC condensor brackets completely
Here it is relocated to drivers side:
For the shifter go to http://www.karcepts.com and pickup his kit. Basically it's a mounting plate that holds the shifter in place while protecting it completely and give your car a stock shifter look:
The underside (silicone to seal):
Test fitment (OEM y0!);
You'll need to mod the fuel system and get an adjustable FPR to set fuel pressure to 52-53psi
You'll most likely need to fab up some sort of intake (depends on what intake manifold you go with) I just used an rsx intake but as you can see it's not in the best position. That's why I used the head shield:
Barely see the FPR gauge :
You'll need to make a custom exhaust to clear the karcepts kit:
The bend:
You'll need a mix of k/b axles or aftermarket ones. You'll need a custom harness from hybrid-racing.com, you'll need kpro (should have it). I'm forgetting stuff but I gotta work.
Here's what my i/h/e k24 dynoed at:
This swap isn't for everyone. You need time, money, patience, you need to actually enjoy working on your car. you need to have ***** and try **** on your own when no one knows the answer.
Old Sep 15, 2005 | 06:17 AM
accordselux's Avatar
Me Gusta History
Default Re: K20 into EK? (litterbox)
still gooing over this one...and bookmarking it so I can see how it looks!
Old Sep 15, 2005 | 04:58 PM
Sleepy_Red_hatch's Avatar
Default Re: K20 into EK? (accordselux)
up...nice work litterbox
Old Sep 15, 2005 | 05:40 PM
bad93ex's Avatar
How much is a k20 swap?
Old Sep 15, 2005 | 05:57 PM
litterbox's Avatar
Default Re: (bad93ex)
Between $7-12k
Old Sep 15, 2005 | 05:59 PM
tthomass's Avatar
amatuer
Old Sep 15, 2005 | 07:04 PM
A-busive's Avatar
Default Re: (litterbox)
So now u have it..is it worth it???I heard their still new so they can produce more problems...
Old Sep 15, 2005 | 08:13 PM
SikBubble20's Avatar
Default Re: (A-busive)
i heard that you have to use a eg subframe for the swap actually i read is this true?
Old Sep 16, 2005 | 05:00 AM
litterbox's Avatar
Default Re: (SikBubble20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SikBubble20 &raquo;</TD></TR><TR><TD CLASS="quote">i heard that you have to use a eg/dc subframe for the swap actually i read is this true?</TD></TR></TABLE>No, you don't have to since hasport releeased a 2nd gen of EK mounts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A-busive &raquo;</TD></TR><TR><TD CLASS="quote">I heard their still new so they can produce more problems...</TD></TR></TABLE>That's crap. Besides, the motor I bought had 10miles on it at time of purchase. It now has 300.
Old Sep 16, 2005 | 05:25 AM
dpkelly's Avatar
Wow! Nice work! That's more horsepower than the new 2006 civic Si and at a fraction of the cost!
Old Sep 16, 2005 | 06:50 AM
JAdams93's Avatar
me and a couple of my buddys did a k20a swap into a 93 eg and the motor was in the car that night and it was running the next day. we used hasport mounts and the hondata k-pro ecu and every thing ran fine but we got the motor form H-motors online and they gave my friend a pretty good deal.
k is the only way to go!!!!!!!
Old Sep 16, 2005 | 07:02 AM
mwieczorek43's Avatar
Default Re: K20 into EK? (JAdams93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JAdams93 &raquo;</TD></TR><TR><TD CLASS="quote">the motor was in the car that night and it was running the next day. </TD></TR></TABLE>
You want a cookie?
I don't know if I believe all that modding and fabbing can be done in one night.... ?
I've seen people spend weeks on a K swap. But that's just me.
I do agree that hmotorsonline is the ish
Old Sep 16, 2005 | 07:34 AM
jezek20's Avatar
heres my k20a2 in my ek hatch. paid 2200 for tha motor, and about 4Gs to install and all the parts i needed. and hell yeah its worth it.
Old Oct 6, 2005 | 10:22 PM
tukin17's Avatar
great writeup bro i would love 2 do 1 of theses motors but a lil out of my league
Old Oct 6, 2005 | 10:40 PM
allmotorgsrcivic's Avatar
Default Re: K20 into EK? (tukin17)
i am about to do my swap and was curious if i had to buy axles or could i use the rsx axles. last question is how hard was it for you to put the shift box like that and will it get in the way of the exhaust?
Old Oct 7, 2005 | 09:42 AM
litterbox's Avatar
Default Re: K20 into EK? (allmotorgsrcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorgsrcivic &raquo;</TD></TR><TR><TD CLASS="quote">i am about to do my swap and was curious if i had to buy axles or could i use the rsx axles. last question is how hard was it for you to put the shift box like that and will it get in the way of the exhaust?</TD></TR></TABLE>Sorry for never following up. Companies make axles for k into EG or EK applications. Try hasport.com or drive shaft shop, or itunedusa.com. Or you could use rsx shafts with B series outer hubs. That works, and they hold up to abuse at the track.
The shifter isn't too hard of an install. AEM made a header that sells for $470 that puts the merge collecter flange right at the exact spot so you can just bolt up a civic catback exhaust. That's really ******* easy.
Old Oct 7, 2005 | 01:11 PM
hellsyea2020's Avatar
nice! .....from wut i understand the k20 is the best new motor u can get ....i hear its really reliable
Old Oct 7, 2005 | 01:38 PM
hushypushy's Avatar
Default Re: (jezek20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jezek20 &raquo;</TD></TR><TR><TD CLASS="quote">heres my k20a2 in my ek hatch. paid 2200 for tha motor, and about 4Gs to install and all the parts i needed. and hell yeah its worth it. </TD></TR></TABLE>
...that's ridiculously cheap...too good to be true cheap, in fact...
Old Oct 7, 2005 | 01:45 PM
JDM-EJ1's Avatar
Andy, you're the ******' man. That swap is killer.
Old Oct 7, 2005 | 04:40 PM
MKIIISupra's Avatar
What kind of times could one expect from a stockish K20 swap?
Old Oct 14, 2005 | 09:17 AM
Ekay Jay's Avatar
Default Re: K20 into EK? (MKIIISupra)
For some great info that hopefully I will need in the future
Old Oct 14, 2005 | 10:03 AM
error's Avatar
Default Re: K20 into EK? (JdM DA InTeGrA)
how long would it take you to drop a fully assembled k24 in the chassis(96 cx)? my problem is that i only have one car, and i must commute to school ect... plus it would be my first DIY swap. comments or suggestions?
Old Oct 14, 2005 | 10:07 AM
litterbox's Avatar
Default Re: K20 into EK? (error)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by error &raquo;</TD></TR><TR><TD CLASS="quote">how long would it take you to drop a fully assembled k24 in the chassis(96 cx)? my problem is that i only have one car, and i must commute to school ect... plus it would be my first DIY swap. comments or suggestions? </TD></TR></TABLE>I started my swap during the third week of July. I finally got every ******* problem straight last sunday.
Old Oct 14, 2005 | 10:14 AM
error's Avatar
F%ck it, ill take the bus then! btw whats your prior experience with mechanics? judging by your pics, you look like a pro
