replacing timing belt and clutch on b16...pull motor or not?
Old Sep 14, 2005 | 08:20 PM
coot_er's Avatar
Default replacing timing belt and clutch on b16...pull motor or not?
well i never did replace the timing belt, water pump and tensioner on my b16a so i really need to do it before it breaks. my clutch is also worn out so im replacing the clutch and having the flywheel resurfaced. should i pull the engine to do it or do one side at a time???
Old Sep 14, 2005 | 08:43 PM
RaysBoomBoomLude's Avatar
Default Re: replacing timing belt and clutch on b16...pull motor or not? (coot_er)
Well, Its a given that working on the motor outside of the car is a million times easyer. BUT its really up to prefrence.
well you already need to remove the axles, shiftlinkage. to get the trans out.
Just a little bit more work, and you can pull the entire motor.
personaly. I think if your going to do so much work, pull the motor.
Old Sep 14, 2005 | 09:03 PM
snowseeker's Avatar
Default Re: replacing timing belt and clutch on b16...pull motor or not? (LaFawnduh)
For what you are doing every mount will have to be unbolted, pull the motor!
Old Sep 15, 2005 | 08:49 AM
g-ride-si's Avatar
I owuld get the tranny off and support the motor with a jack while you do the timing belt. This way you will be able to move the motor around and have room, but you wont have to go through the work of dropping the motor back in, which with b series can be a bitch. Just imo though.
Old Sep 15, 2005 | 09:09 AM
cmyrex's Avatar
I would pull just cause you have half the stuff out to pull motor. Find some others things that may need to be replaced also, mightest well you have the entire engine out.
Old Sep 15, 2005 | 09:20 AM
vtecn8ive's Avatar
Default Re: replacing timing belt and clutch on b16...pull motor or not? (cmyrex)
i'd pull it
corkss
Sep 3, 2008 07:54 PM
nemesis25
Jul 5, 2007 03:47 PM
.Unknown.
Sep 15, 2005 07:35 PM
Volcom
Dec 28, 2002 10:50 AM
