buddy club Spec IV cams
Old Sep 14, 2005 | 07:01 PM
ganjafarmer143's Avatar
Default buddy club Spec IV cams
hey i've decided to get the buddy club spec IV...to run the spec IVs my compression is good as is but other than the retainers, valve springs and cam gears what else would i need?...do i need management and injectors? or would the springs cam gear and retainers be all i have to get?...oh and would the car idle?
Other question!...how true is it that if your compression is 12.5 to 1 then u need to use race gas?...plz let me know if this is true
Please try to help as much as possible
Thanks in advance
Old Sep 14, 2005 | 07:52 PM
PRcivicHB's Avatar
Default Re: buddy club Spec IV cams (ganjafarmer143)
for some stage 4 cams, I would think u need some high asz compression, and for high asz compression you obviously need some sort of good fuel management to keep it from detonating.
search bro, Im sure you will find your answer if you research first...
Old Sep 25, 2005 | 05:52 PM
bull2k4's Avatar
my boy smokey2.0 has the stage IV's in his b20/vtec. his compression is about 9.2:1. he has springs retainers and cam gears. hondata program....no problems....runs great...
Old Sep 25, 2005 | 05:54 PM
fekyoride's Avatar
Default Re: buddy club Spec IV cams (bull2k4)
if ctr cams cause the valves to kiss b20 pistons, why would a bigger cam have no problems with clearance? My buddy smokey does it so you should too!
bluedlude
Nov 29, 2006 10:12 AM
EKB18C97
17
May 2, 2006 03:30 PM
TyPe-R6
Dec 23, 2004 07:53 AM
DevinW
Dec 4, 2003 04:17 PM
eh294
Aug 15, 2003 09:15 PM
