bi-xenon hid question
i've been looking at some hid conversion posts on here lately, and i plan on retro-fitting some into my 5th gen. i understand how the ballasts and bulbs wire up and everything. i also like the idea of the bi-xenon projectors. but what i don't understand is how to get the high beam part of it is wired up. can anyone explain how to power the motor in the bi-xenon projectors?
all you do is wire up just the high beam positive wire to the ballast, and so when you flip it to the high beams, the solenoid clicks open. and the high beams open up. and the high beam negative just grounds. just make sure when you put the projectors in the housings, to leave room for the little door to open up when you flip on the high beams...
