Swapped JDM B16A Throwing Map Sensor Code
Old Sep 14, 2005 | 10:59 AM
JibOnALib's Avatar
Default Swapped JDM B16A Throwing Map Sensor Code
Alright I swapped in an obd1 jdm b16a into my 94 si and I'm throwing the map sensor code. From what I have read the map sensor is located on the firewall in japan, so I wouldn't have one. Now I have read you can get a map sensor, and hook it up or you can switch out the throttle bodies. Now can I just get a GSR or Type R throttle body and run that? I am also throwing a TPS code, and my TPS is hooked up correctly, so do you think the TPS could be bad on this motor?
Old Sep 14, 2005 | 11:01 AM
Suck my DX's Avatar
Default Re: Swapped JDM B16A Throwing Map Sensor Code (JibOnALib)
of course u have a map sensor...it is one of the most vital sensors for ur engine...it is located on ur firewall...are u throwing code 3 or 5...make sure ur sensors are properly connected as well as ur vac lines...
Old Sep 14, 2005 | 11:03 AM
JibOnALib's Avatar
Default Re: Swapped JDM B16A Throwing Map Sensor Code (Suck my DX)
I'm throwing code 3.
Old Sep 14, 2005 | 11:08 AM
9hatchman4's Avatar
I have the same problem with mine, except I have a gsr in my hatch, and it's boosted. Do you have the knock sensor wired up? When I was na I didn't have it hooked up, and that's the only code it threw, but once I boosted mine it started throwing all kinds of codes. Is there a safe mode that the car goes into to throw the tps code? I already know why I'm throwing a map sensor code. Anyway looks like we have a similar problem so if anyone has any ideas let's hear em. Thanks in advance.
Old Sep 14, 2005 | 11:11 AM
JibOnALib's Avatar
Default Re: Swapped JDM B16A Throwing Map Sensor Code (9hatchman4)
I had a gsr in it before this, it didn't throw any codes.
Old Sep 14, 2005 | 11:22 AM
Suck my DX's Avatar
try replacing them with known working ones and see if it solves it...if not, then there is a chance that some wiring might have gotten pinched when u swapped it...or a loose connection somewhere...
Old Sep 14, 2005 | 11:23 AM
JibOnALib's Avatar
I don't believe there's a map sensor on the firewall, I just looked, I think the older civics had the map sensor on the firewall. The car is obd1 and the motor is a jdm b16a that's obd1 as well. On the GSR the map sensor was located on the throttle body i believe, as well as on my z6. So I honestly don't think there's a map sensor, the car is running on limp mode so it wouldn't surprise me.
Now will a gsr throttle body fit on a b16 manifold?
Old Sep 14, 2005 | 11:24 AM
9hatchman4's Avatar
There is not a map sensor located on the firewall on usdm 92-95 civics, it's located on the throttle body or intake manifold
Old Sep 14, 2005 | 11:26 AM
JibOnALib's Avatar
So I will need to get a map sensor and mount it to the firewall right? Or just get like a gsr throttle body (which has the map sensor) if it fits to the manifold.
Old Sep 14, 2005 | 11:35 AM
9hatchman4's Avatar
I guess you could just get a map sensor run a line to the intake manifold and call it a day, or yeah you could just get a gsr throttle body. So do the b16 throttle bodies not have a map sensor?
Old Sep 14, 2005 | 11:38 AM
NJcoupe's Avatar
Have you thought that the map sensor, and the TPS sensor have the same plug and you accidently put them on the wrong plugs?
Old Sep 14, 2005 | 11:39 AM
JibOnALib's Avatar
Default Re: (RHDej2.)
The TPS is hooked up correctly, I've switched both of the plugs, there is no where to plug in the map sensor plug.
Old Sep 14, 2005 | 11:51 AM
Suck my DX's Avatar
Default Re: (JibOnALib)
lol i forgot i wasnt at home..the ef forum
Luillo
Jan 18, 2013 08:08 PM
eggie75
Apr 7, 2008 01:40 PM
FSS13foxtrot
Jan 20, 2008 06:23 AM
D C 5
Jun 19, 2005 11:01 AM
NotPhilTran
Apr 27, 2004 07:08 AM
