5th gen Euro R swap: No Spark! help needed ASAP!
Ive searched, researched, asked around... nothin...
Me and a friend of mine completed a Euro R swap into my 5th gen. p28 obd1 ecu, swapped the stock USDM 5th gen distributor, stock USDM wiring harness, USDM external coil all from my stock motor.
Car is cranking and wants to start but NO SPARK? checked cyl # 1 plug and found no spark. Changed the ignitor, changed the distributor cap and rotor, swapped a new coil, checked for fuel... no spark... checked for CEL codes.... none came up just a 1-1 and 2-1 for SRS which is probably from me taking out both bags.
Any help would be greatly appreciated so I can avoid towing to the nearest dealership. An 18 pack will be rewarded if someone can roll by and figure this out!
or some other reasonable compensation. if its something minor and someone knows what to do please post it, thanks in advance!
