can to much oil cause ALOT of white smoke?
ALOT of white smoke is usually a blow head gasket, is the car overheating or the coolant in the resevoir tank boiling? Check the dipstick there should not be any coolant in the oil. Oil burning is a blue smoke
No ma'm.
Too much oil in ur engine will not allow the oil to do its job the best it can. Also, too much oil will eventually wear down gaskets that keep the oil in the block. If a gasket blows then it will cause a leak.
Thats all
Thats all
