Two Reminders Regarding Tire Pressure
Here are a couple of tips regarding your tire pressures.
First, check the pressure in your spare tire! It's supposed to be 60 psi. I'm sure a lot of folks haven't checked it in a while. You don't want to wait until you need it to find out that it's underinflated or flat.
Second, this is the time of year when the weather is cooling off. That means that it's the most important time of year to adjust your tire pressures. Pressure drops by about 1 psi for each 10 degrees F drop in temperature. That means that if you checked your tires when the highs were 85, and now they're 65, you will have lost 2 psi just due to the cooling off after summer. Measure them when cold (when the car has been sitting a while, out of the sun) when the temperature is about the same as when you usually drive.
Let's roll!
Let's roll!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpsadmin »</TD></TR><TR><TD CLASS="quote">what is your R's tire pressure? I haven't check mine for 8 months.</TD></TR></TABLE>
The recommended tire pressures for the ITR are 35 front, 33 rear.
Tires can lose 1 psi per month, even without any leaks. You really ought to check tire pressures at least once a month.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">Second, this is the time of year when the weather is cooling off.
Really? I haven't noticed....
Shitty south florida.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny »</TD></TR><TR><TD CLASS="quote">
Shitty south florida.</TD></TR></TABLE>
hahahah ditto. yO man havent talked to you in a long while are you down to do a sebring event?
Ive been trying to find someone to do one with. let me know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">Here are a couple of tips regarding your tire pressures.
Let's roll!
uhoh! My spare is only at 32psi!
-Dave, who has a 205-50-15 spare on an OEM wheel
on the reminder for those with actual spares though, I have made the mistake of not checking and getting a flat. F@!$##$#CK!
Let's roll!
SkRiBLaH
10
Feb 16, 2004 09:25 AM
to you sir for reminding me i am a noob.
